Repair Guidance
'86 K75C - Installing Engine Guards - HELP!
Topic: '86 K75C - Installing Engine Guards - HELP! (Read 8903 times)
2000rsv
^ Motobrick Curious
Ride Far - Ride Fast
August 13, 2012, 12:08:38 AM »
Purchased a set of K75 engine guards from another rider. It came with brackets, hardware, and both guards.
I can't for the life of me figure out how these things go on.
Does anybody have instructions?
Thanks, J
AMA 1097757, IBA 33089, TS 700
2009 GSA, 2012 K1600GT, 2008 KLR650, '86 BMW K75C, and always a couple of projects
Scott_
Administrator
Re: '86 K75C - Installing Engine Guards - HELP!
Reply #1 on:
August 13, 2012, 06:59:53 AM »
Well there are 3 mounting points for each side.
The 2-point brackets bolt to the threaded holes in the bottom edge of the oil pan(one on each side).
There may be some rubber plugs in the holes you need to remove.
The upper part of the bracket uses another (adapter bolt) that replaces the existing engine/frame mounting bolt.
I presumed you are talking about just the "standard" guards for the front, not the extra "rear" set for the police version, as I don't have a clue how they bolt up.
My Garage
2000rsv
^ Motobrick Curious
Reply #2 on:
August 13, 2012, 07:16:02 AM »
Scott,
Thanks for the info. Yes, they are just the standard guards.
I will check out the mounting you described. If it doesn't make sense, I will take some pictures so we can figure out what I am screwing up.
J
bmw-rider
Motobrick Curious
Reply #3 on:
August 13, 2012, 08:26:25 AM »
Hi J
Would this help?
grtz. Dick
2000rsv
^ Motobrick Curious
Reply #4 on:
August 13, 2012, 09:01:27 AM »
Quote from: bmw-rider on August 13, 2012, 08:26:25 AM
Hi J
Would this help?
grtz. Dick
Why yes; yes it would.
That is exactly what I was hoping to see.
Where did you find this?
Thank you.
J
bmw-rider
Motobrick Curious
Reply #5 on:
August 13, 2012, 09:12:45 AM »
here
and
here
