Author Topic: '86 K75C - Installing Engine Guards - HELP!  (Read 8904 times)
Offline 2000rsv
  • Ride Far - Ride Fast
« on: August 13, 2012, 12:08:38 AM »
Purchased a set of K75 engine guards from another rider.  It came with brackets, hardware, and both guards.
I can't for the life of me figure out how these things go on.
Does anybody have instructions?
Thanks,  J
AMA 1097757, IBA 33089, TS 700
2009 GSA, 2012 K1600GT, 2008 KLR650, '86 BMW K75C, and always a couple of projects
Re: '86 K75C - Installing Engine Guards - HELP!
« Reply #1 on: August 13, 2012, 06:59:53 AM »
Well there are 3 mounting points for each side.
The 2-point brackets bolt to the threaded holes in the bottom edge of the oil pan(one on each side).
There may be some rubber plugs in the holes you need to remove.
The upper part of the bracket uses another (adapter bolt) that replaces the existing engine/frame mounting bolt.
I presumed you are talking about just the "standard" guards for the front, not the extra "rear" set for the police version, as I don't have a clue how they bolt up.
Offline 2000rsv
« Reply #2 on: August 13, 2012, 07:16:02 AM »
Scott,
Thanks for the info.  Yes, they are just the standard guards.
I will check out the mounting you described.  If it doesn't make sense, I will take some pictures so we can figure out what I am screwing up.
J
Offline bmw-rider
« Reply #3 on: August 13, 2012, 08:26:25 AM »
Hi J
Would this help?
grtz. Dick
Offline 2000rsv
« Reply #4 on: August 13, 2012, 09:01:27 AM »
Hi J
Would this help?
grtz. Dick
Why yes; yes it would.
That is exactly what I was hoping to see.
Where did you find this?
Thank you.
J
Offline bmw-rider
« Reply #5 on: August 13, 2012, 09:12:45 AM »
