Laitch:
The battery and grounds were removed cleaned and reinstalled…reply 1 ( Bike was sitting for a decade and all electrical connections were removed& cleaned.)
The battery…at 12.5 was tested using my battery load tester…showed good…re- assess as needed, 4 months old…
…The bike always seemed to charge and start right up. I never thought to test the charging system, when I did I still thought 13 Volts was sufficient to run…ignition. Guess it may not be.
So....now, I removed and bench tested alternator ( to clean all brushes & contact areas also )
Turns out she is tired. Ohms across the two brass armature rings should be 2.5….they read 5
Changing the original 40 year old alternator makes sense…as did the temperature sender ( ohm reading not perfect) and hall sensor….not big ticket items.
The coils and wires checked out ok and were not replaced.
I am following a logical order here not haphazardly changing stuff.
This is a $750 barn find…so I was expecting some costs….It still has the original fan!
Thanks for your …..help. 😳😳
