Author Topic: 85 K100 ...all of a sudden backfiring and stalling when HOT! Still not fixed!  (Read 3307 times)
Offline Edward
Yes that is correct, the airbox and yes, he fuel pressure regulator is behind it.
  • Philadelphia, Pennsylvania USA
  • K75s 1987, MV Agusta Brutale 910s 2008 | Original owner
K75s 1987  | Original owner | RK BMW
MV Agusta Brutale 910s 2008 | Original owner | FBF
Is something wrong with the fuel pressure regulator, or is it to be part of a feng shui reorganization?
Offline Atabeach
Am I mistaken to believe a faulty fuel regulator could cause a rich running condition? The temperature sender , TPS and coils seem to be fine. I’m just going with process of elimination. Does anyone think 13 volts is not enough to run the ignition system. Please advise.
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
I don't believe an alternator outputting 13V while the engine is running is capable of producing engine performance reliably.
Certainly, a fuel pressure regulator be a cause of over-fueling, but so can a clogged fuel return line, a faulty fuel pump or a faulty fuel injection control unit, not to mention the air flow meter which can be tested in place rather than on a bench. Repair using the process of elimination can be too costly for many of us; that's why there's all the testing; however, replacing parts also can eventually improve performance, if the defective part—or parts—eventually are replaced. That seems to be the diagnostic strategy with this Brick. AI can make a great companion for that.
Offline Atabeach
Thanks Laitch,  I will take your advice and change the alternator….and move forward from there if there is no improvement….further, I was mistaken. I thought the alternator voltage at 13 would have been more than enough.
This model 1985 has a 33 amp alternator. Would anyone recommend a rebuild kit? Otherwise I am buying used off of Flea bay....
  • Ponte Vedra Fl
That isn't my advice.
The battery reading should be ≈13.5V to 14.5V with the engine running. Resting voltage should be 12.6V or above. Why do your battery's figures differ? My advice is to determine the root of each condition one step at a time. Why is your Brick's battery at 12.5V instead of within the optimal range. One case here where the battery wasn't holding a charge was caused by the alternator's cable connection to the battery being loose at the alternator side. Another case involved a bad diode.
All electrical connectors and ground connections of a 40 year-old Brick are first suspects when engine performance is erratic. The components themselves are the next suspects.
Offline Atabeach
Laitch:
  The battery and grounds were removed cleaned and reinstalled…reply 1 ( Bike was sitting for a decade and all electrical connections were removed& cleaned.)
The battery…at 12.5 was tested using my battery load tester…showed good…re- assess as needed, 4 months old…
…The bike always seemed to charge and start right up. I never thought to test the charging system, when I did I still thought 13 Volts was sufficient to run…ignition. Guess it may not be.
  So....now, I removed and bench tested alternator ( to clean all brushes & contact areas also )
Turns out she is tired. Ohms across the two brass armature rings should be 2.5….they read 5
 Changing the original 40 year old alternator makes sense…as did the temperature sender ( ohm reading not perfect) and hall sensor….not big ticket items.
The coils and wires checked out ok and were not replaced.
  I am following a logical order here not haphazardly changing stuff.
This is a $750 barn find…so I was expecting some costs….It still has the original fan!
Thanks for your …..help. 😳😳
  • Ponte Vedra Fl
Offline Atabeach
So the alternator was changed I am getting a solid 13.7 at around 2500 rpms. Battery was swapped with my other bike...no difference. I changed out the fuel regulator (used) no improvement....The bike always starts right up and idles smoothly at 12/1300 rpm. It backfires when revved or put under load by riding. It smokes at all rpms and all the plugs are still wet with gasoline.
  • Ponte Vedra Fl
Offline Edward
I wonder if your coolant temp sensor is faulty, causing the ecu to think the engine is too cold therefore pumping more fuel than needed? I don't recall but did you adjust your bleed screws to have a in-sinq throttle body?
Offline Atabeach
The temperature sensor was changed.  I have not adjusted the screws because the bike was running fine…This happened suddenly. Thanks
  • Ponte Vedra Fl
Offline Edward
tps reset?
