Author Topic: 85 K100 ...all of a sudden backfiring and stalling when HOT! Still not fixed!  (Read 4880 times)
Offline Atabeach
The problem is occurring when the bike is cool also. I took the bike out today and it ran fine for a while.
Some observations and my thought process:
When the problem occurs the front exhaust pipe tube and the rearmost pipe are significantly cooler.  Using an infrared sensor confirms this….They are not firing as they should.  I believe this is cylinder 1 & 4
Tests:
  when the problem is occurring… I will use a test lamp at the back of Hall sensor connection , pin 2 and or 5 to negative terminal…).
   When the problem is occurring I will test the black wire clip on coil 1 & 4 …to a positive terminal. Depending on results…
I will then bench test coil or swap them with extras I have.
Please let me know if this makes sense or if I am missing something
TIA
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Yep, that makes sense.
We don't know the quality of your spare coils. One option, swap the coils on your bike, if the problem transfers to cylinders two and three,  it's probably a bad coil.
On my 1984 brick, both coils had cracked cases, but the cracks could only be seen after removing the coils. They both had open circuits, so that would probably be a quicker test than swapping them.
Notice in the Hall sensor video that the test wire is clamped to the battery negative post, not the positive. It is tricky. The pulsing signal from the Hall sensor is positive, but the pulsing signal from the computer is negative.
To muddy the waters even more, they came up with a real doozy. I would have loved to be in the meeting room when they designed this one, but I can imagine how it went. Someone in the meeting says "Hey, the two positive signals from the hall sensors, let's have an orange wire for one, and a brown wire for the other, because every other brown wire on the bike is negative" They all started laughing, then someone says "good one Fritz, let's go with that"
Offline Atabeach
 so the coils were tested on bike and then removed..bench tested...2.6 ohms
COILS GOOD.
The hall sensor was bench tested...good..UNTIL
The hall sensor connection was tested ON BIKE...( 12 SECOND VIDEO ) .Orange to lamp to negative terminal..No light! Same with Brown.
WTF! the bike starts!
  • Ponte Vedra Fl
Too early to start the party.
COILS GOOD.
What's the value at the secondary terminals?
It's good to know I'm not the only one who has WTF moments.
When I found out that both coils on my brick were open circuit, I said to myself "WTF, but the bike starts and runs" So I said it again, I said "Daveson, what the fuck"
It was very difficult to start, but when warm it would start easy and run well.
Here's my guess, which may apply in your case as well. I guess there was a crack somewhere along the circuit. Depending on the location of the crack, sometimes the crack gets larger when warm, sometimes it gets smaller. The electricity can jump the gap, as it does at the spark plug. The Hall sensor problem could be opposite to the coil problem I had, therefore when it gets warm, the gap gets bigger, and it struggles to cope. I think the situation with my coils was very unusual, because every other time I've heard about coil problems, they failed when they got warm.
Maybe it's just the hall sensor plug. I would repeat the test on both sides of the plug. If the test result is good on the input side of the plug, then you need a new plug, because the test result was a fail on the output side.
Of course you aren't; we even have an emoji here for the occasion.  :thisplacewhack
Offline Atabeach
W-T-F..
Laitch…OL reading across both secondary spark plug terminals in BOTH coils. I used two different multi meters. 2.8 across primary. The bike starts and runs.
Observations, With the bike running:
Test light from primary coil to ground illuminated test light but slowed idle. (Probably normal)
Test light from hall sensor female pins ( back of clip ) 2 & 5 to negative terminal did not illuminate small led or test lamp…
The fan clicks on normally when hot.
Continuity between hall sensor disk  & wires / wire pins are good.
Not sure where FEMALE pins lead…please advise! I want to test continuity.
Question: I have 3 K 75 coils. Can I safely remove one primary wire & spark plug wire …and attach to one of the K75 coils?
  • Ponte Vedra Fl
Laitch…OL reading across both secondary spark plug terminals in BOTH coils. . . .  I have 3 K 75 coils. Can I safely remove one primary wire & spark plug wire …and attach to one of the K75 coils?
:thisplacewhack
Wow, I always thought of that as meaning "nothing to see here" or "boring"
I hope I haven't put any noses out of joint in the past, due to my misinterpretation of that one.
It was labeled by its creator (or enabler), "Thisplaceiswhack".  :laughing4-giggles:
But was the light pulsing? I suppose it was. It's more rapid at idle than while cranking, so more difficult to see a pulsing.
Test light from hall sensor female pins ( back of clip ) 2 & 5 to positive terminal did not illuminate small led or test lamp…
With positive on both sides of the test light, the light will remain off.
ALERT! This morning started bike…ran rough ….TEST LIGHT from pin 2 & or 5 to positive shut bike IMMEDIATELY …test lamp does NOT illuminate
...the light...
Again, with positive on both sides of the test light, the light will remain off. This test provides constant power to the hall sensor, so the pulsing signal is lost, therefore the engine stops.
Don't test continuity because your multimeter supplies power to do this, Hall sensors are very sensitive and can easily be damaged. This is probably why Bert's guide warns us not to use an Ohmmeter for Hall sensor tests.
The Hall sensor signals go to the ignition control unit.
I wouldn't, K75 coils are different.
One safe test would be to swap the coils to see if the problem transfers to the other two cylinders.
Offline Atabeach
Daveson, I wrote it incorrectly the lead from back of hall sensor is to the negative side. Light does NOT illuminate…with ignition on or while cranking. Further, I bench tested Hall sensor again. 👍🏻
….both coils seem to provide good spark. The plugs are wet so for now I am hoping the new Bosch temperature sensor will solve problem.
Daveson, thanks again
My new addition is up and running ( see photo )
…another barn find 🙄🙄🙄
  • Ponte Vedra Fl
Offline Atabeach
Soooo A new Temperature sensor arrived today....still running poorly.
I did notice today that the voltage ( 12.4 at idle ) never climbed above 12.9 when increasing RPMs. The battery is new and tests "good" on my battery tester even under "Load"
  • Ponte Vedra Fl
What is the battery voltage when the ignition switch is Off?
Offline Atabeach
12.5 Volts. With some lights off she climbs to 13.2ish
I tested the TPS with test lamp and multimeter...zero ohms from pin 1 & 2....test lamp on until I turn the throttle.
Pressing the starter button at idle bogs the bike down instantly.
  • Ponte Vedra Fl
Your response to my query seems to indicate that some lights are on when the ignition switch is turned to Off. Is that the case?
Offline Atabeach
No…12.5 volts ignition off. 13.2 with the bike, running at about 4K…accessory lights off
  • Ponte Vedra Fl
The battery seems weak and so does the alternator charging current. Has the battery light in the instrument cluster been intermittently flickering or faintly glowing when riding or idling?
Offline Duckbubbles
I had to replace the alternator on my '85 K a few months ago and the new one read 14.0 volts at idle.
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'23 R1250RS
'03 R1100S BCR #6/200
500,000+ BMW miles
Offline Atabeach
No. The alternator goes out and remains out unless she is about to stall. Agreed..13 volts low but should run the bike.
  • Ponte Vedra Fl
Please update.
Does the Brick start reliably? Does it ever start and idle until shut off?
Does it idle smoothly?
Can it be ridden any distance at all without conking out?
Offline Atabeach
She stars reliably, one shot. Idles rather smoothly…at 1k …anything below 1k she will stop running. When I hit gas she backfires and surges. She surges and cuts out when ridden. She constantly blows smoke.
My thinking:
Although 13 v is plenty…I’m going to change alternator as it is probably getting tired.
I have a used fuel regulator from a k75…I’ll change it
While the airbox is out I will bench test the airflow meter.
….let me know if that makes any sense.
  • Ponte Vedra Fl
Is the airbox out now? If it isn't, why is it being removed?
Offline Atabeach
The fuel regulator is behind it…am I using the wrong terminology again.? The black box thingy that holds the air filter….
  • Ponte Vedra Fl
