Author Topic: 85 K100 ...all of a sudden backfiring and stalling when HOT! Still not fixed!  (Read 40885 times)
Offline Atabeach
Ok was running absolutely perfect, yesterday...she always backfired under deceleration but now on low rpm throttle. Starts right up, soon as the temps get up backfiring & stalling on low RPM.  OK soooo I used the propane trick to check for leaks at the throttle bodies...no noticeable increase in RPM. Pressed the starter button, verrrry slight decrease in RPM. The fuel pump is new , Z hose new...checked for leaks in and around air box... next Im going to take out plugs and see how they look. any usual suspects Im missing? TIA
HALL SENSOR...
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Re: 85 K100 ...all of a sudden backfiring and stalling when HOT!
« Reply #1 on: June 27, 2026, 04:56:38 PM »
Verify that the battery positive clamp, the battery ground clamp and the battery ground cable attachment on the transmission are tight.
Click this link to the opening post of the Service Manual section here. Click on the link to Vogel's troubleshooting guide at the bottom of the opening post. Perform the tests of the throttle switch and the coolant temperature sensor explained on pp. 25–29. Let us know the results.
Offline Atabeach
« Reply #2 on: June 27, 2026, 08:56:01 PM »
Thanks Laitch, So I checked the Grounds and Positive terminals and then spent about an hour reviewing Vogels detailed post. Very informative, thanks.
1) The post referenced non start issue regarding throttle switch. Page 7/8 I did not see how to test it. For historical purposes the bike is an 85 and …backfires. Maybe It should be changed. Please advise.
2) I did not see how to test coolant temperature sensor either. Please let me know the ohm value or how to test the unit ….
 I did discover an oil leak coming from the bottom of the air box ( photo 1)
 Thanks again.
  • Ponte Vedra Fl
« Reply #3 on: June 27, 2026, 10:22:49 PM »
The photo of the air box in your post is of the intake air system on an 4-valve engine, not a 2-valve engine as should be in an '85 K100. The 2-valve air box that connects to the throttle bodies is pictured below. What's going on, Florida Man?  :laughing4-giggles:
Offline Atabeach
« Reply #4 on: June 27, 2026, 10:38:17 PM »
Ok soooo no internal hose, Check!
Can i assume since the fan clicked on the coolant sensor is good?...or is there a different sensor?
In Vogles post he stated that the hall sensor seemed to act up when heated...we are in Florida.
  • Ponte Vedra Fl
« Reply #5 on: June 27, 2026, 10:59:35 PM »
Check? None of that assembly belongs on a 2-valve K100 Brick so what's a photo of it doing in a thread about the performance of a 2V Brick engine? I don't know what you've got going down there in the steamy sub-tropics. Will you offer a comprehensible explanation? My next dose of coffee isn't until after 8am tomorrow.
 177381
Offline Atabeach
« Reply #6 on: June 27, 2026, 11:08:46 PM »
The photo was posted in error, I will attempt to remove it.
  • Ponte Vedra Fl
« Reply #7 on: June 28, 2026, 03:50:29 PM »
* IMG_7491.jpeg (53.38 kB . 768x576 - viewed 521 times)
Is this a photo of one of your Brick's throttle bodies? If it is, what is the blue linear object in it?
Offline Atabeach
« Reply #8 on: June 28, 2026, 04:40:11 PM »
Throttle body nearest to Z hose ...Blue object is pointer to the area of oil leak...
  • Ponte Vedra Fl
« Reply #9 on: June 28, 2026, 10:09:45 PM »
The 2V air box has throttle body intake pipes molded into it as can be seen in previous post #3. There are no joints in the box’s construction to leak; it would need to be cracked. Leaking is unlikely because crankcase blow-by is received into the air box from the z-tube then mixed with air being drawn from the box through the throttle bodies. Oil shouldn’t be "flowing" anywhere in the air box to create a leak. Oil should be in blow-by vapor that enters the throttle bodies to then be ignited in the cylinders. It’s possible that the z-tube is leaking where it is attached causing some oil vapor to condense on the outside of the air box instead of all oil vapor entering the throttle bodies. If the intake rubber hoses were leaking, that would have been evident in your propane test.
Closer inspection is needed.
Offline Atabeach
« Reply #10 on: July 01, 2026, 05:48:58 AM »
Further inspection revealed some oil at the top of Z hose so that is probably where the oil is coming from….obviously not the reason for the bike running poorly.
The post by Vogel specifically mentioned running rough when bike is hot would point to the Hall sensor. I tried to remove it from the bike to test it but the 5 pin connector crumpled miserably in my hand. I need to change it anyway so hopefully that was the issue.
  • Ponte Vedra Fl
Offline Atabeach
« Reply #11 on: July 03, 2026, 04:31:34 PM »
  It was the Hall sensor. Vogel had it right...when the bike fails when HOT....
  • Ponte Vedra Fl
Offline Edward
Honeywell S7C - 2AV54 a discontinued parts from long long ago. Try Chen Yang CYHME56 Hall Vane Sensor. High temp leads may have to be added. Current price 1-10 $5.00.
https://www.chenyang-gmbh.com/en/hall-effect-vane-sensor-cyhme56c-output-npn-oc-power-supply-4.5-v-24-v-dc-alternative-for-2av54-2av16a-2av51a-2av56-honeywell.html
  • USA
  • K75s 1987 Original owner
Offline Atabeach
« Reply #14 on: July 07, 2026, 09:39:05 PM »
Gentlemen…the issue is not resolved. Ok a few rides and the bike fairly warm no problems…Then a nice decent ride…the problem still exists. Backfiring , only runs at 3500 rpm. What are the odds of another bad hall sensor?
  • Ponte Vedra Fl
Test the coolant temperature sensor as was recommended in Reply #1. It's a simple test.
The multimeter is set to Ω. The ignition switch is Off. The ground lead touches contact #1 of the fuel injection plug, the positive probe contacts pin #10. There's a photo of the plug with the contacts numbered in Vogel's a few pages after the Hall Sensor section. At ambient temperature the multimeter should read approximately 2.5KΩ.
If the values are close to that number, start the engine and point a thin stream of propane at the joint of the z-tube with the air box as shown in your photo of the oil leak. If the revs change during spraying, that's one problem uncovered. If okay, move on.
Here's a way to test the hall sensors without removing them.
This short video only shows the test results for one output, the test should be done for both, the brown wire and the orange wire.
https://youtube.com/shorts/P3X0zvDY6Vw?si=V3UK2QuetQEQQroF
If your brick is the earlier model of 1985, the coils aren't the best. You could use a timing gun to check for a good signal from the coils to the spark plugs, or even look at them for cracks. In your troubleshooting guide, there are also tests for the coils.
Offline Atabeach
Thanks Daveson, At this point I will in this order
1) test temperature sensor & propane around z tube , thanks Laitch!
2) test coils ( I think I have spares from box of stuff )
3) remove the used hall sensor I bought and bench test
Thanks, I’ll post the results
Meanwhile in the garage… another barn find. $500, plus handling😳
  • Ponte Vedra Fl
That's one of the rare BMW unicycles. Great find!
Offline Atabeach
Bike cold, starts right up but the hesitation is apparent right away...
1) Quick look at spark plug wires no signs or arcing...Coils no cracks , will bench test shortly.
2) test value of female pin 10 to ground is 1.5...this is below 2.5! I will be replacing temperature sensor either way....
3) bench test hall sensor..pins 2 & 5 ....all appears good.
Q Should I apply heat ( blow dryer ) to hall sensor?
Q Is the value of the temperature sensor @ 1.5 so low as to keep the bike from running?...TIA
  • Ponte Vedra Fl
Don't have my books at the moment so limiting my replies.
Give the electrical plugs a good clean with the help of some electrical contact cleaner.
If the situation is still that the problem is much worse when the engine gets warm, this would be the best time to do tests, as it doesn't have enough time to cool down compared with bench testing. Also it could pass a static bench test, but might not pass a dynamic test while cranking.
Here's another, even quicker test. The test in this twelve second video will verify if the Hall sensor is sending a pulsing signal to the computer, and also verify if the computer is sending a pulsing signal to the coil. Then repeat the test for the other coil. This could be done with the fuse for the fuel pump removed.
https://youtube.com/shorts/5VrtFtr07-4?si=M8VIfew8xUk24JT2
Another video, four seconds long, which should verify that the Hall sensor is sending a pulsing signal to the computer, and that the computer is sending a pulsing signal to the injectors.
https://youtube.com/shorts/Hqttqo-y0xg?si=H2fvwdDZ2N2eMD-G
Offline Atabeach
Daveson, thanks for the 2 videos. … In the 12 second video the probe enters the boot, does the wire lead go to ground… I want to be sure. Thanks
  • Ponte Vedra Fl
If the value at the temp sensor was at 1.5KΩ when the engine was cold, that wouldn't be likely to activate enough fuel for a good start.
The test light clamp is attached to battery positive. I posted more details in the comments section, I probably should have posted it in the description. Actually I should have shown it on the video, it would have only been a few extra seconds.
