Author Topic: K100 ignition coil wires go where?  (Read 11837 times)
Offline Boxermann
« on: May 16, 2017, 08:42:17 AM »
... the green/yellow and blue/black ones that is. Which ones are connected on the outer side?
  • K100 / '87, K75 / '87
Offline know_fear
Re: K100 ignition coil wires go where?
« Reply #1 on: May 16, 2017, 11:34:39 AM »
The green/yellow are the common wires and connect to the inner terminals on both coils. The blue/black goes to the outer terminal of coil 1 and 4 and the red/black wire goes to the outer terminal of coil 2 and 3.
Good luck.
  • BC Canada
  • '85 K100RS, '69 Norton Commando
Know fear,have kids.
Offline Boxermann
« Reply #2 on: May 16, 2017, 04:21:17 PM »
Thanks! Much appreciated.
Offline racket
« Reply #3 on: May 18, 2017, 04:44:14 PM »
Does anyone have a diagram for this?
  • Philadelphia, PA
  • 1986 BMW K100
« Reply #4 on: May 18, 2017, 07:55:20 PM »
Like this
Offline woodgeek
« Reply #5 on: March 01, 2018, 11:09:09 AM »
I'm hooking up some "new" orange tower Bosch coils to my 1985 K100RT and had this same question. To simplify things (the outer/inner part confused me), the blue/black connects to the negative terminal of the 1/4 coil and the red/black wire connects to the negative terminal of the 2/3 coil. The green/yellow wires connect to the positive terminals.
  • Henderson, NV
  • 1985 K100RT
Offline know_fear
« Reply #6 on: March 01, 2018, 01:14:16 PM »
I used the terms inner and outer because the original poster Boxermann used them. You are correct though regarding the polarity of the terminals. After cleaning a few decades of road grunge from the coils I can see that the green/yellow wires connect to the positive terminals.  :2thumbup:
  • BC Canada
Offline woodgeek
« Reply #7 on: March 01, 2018, 01:22:08 PM »
I figured you were using his terminology to help him. I wasn’t meaning to critique your help. I find it curious that though we humans share so many common traits, our internal wiring differs just enough to ensure that we all view things slightly differently. My wife is a teacher and she has to have multiple approaches to teach the same concept because their is no one-size-fits-all approach.
One difference that I didn’t bring up, between the orange tower coils and the solid black ones is that the orange tower coils only have two spade terminals per coil whereas the black coils have three. Does the newer coil do away with a shared ground wire? I’m just guessing that is what the orange wire is as the K is at home and my photos don’t show what the orange wires connect to.
  • Henderson, NV
  • 1985 K100RT
Offline know_fear
« Reply #8 on: March 01, 2018, 02:26:25 PM »
I think the brown wire that grounds the iron core of the coils is the only connection that would be optional.
I'm curious about your orange tower coils. Could you attach a photo? Do they fit under the cover? My stockers have 170,000 Kms on them and I would probably benefit from replacing them.
  • BC Canada
Offline woodgeek
« Reply #9 on: March 01, 2018, 02:48:22 PM »
There are some pics of my new coils in this thread: http://www.motobrick.com/index.php/topic,10799.msg94287.html#msg94287
You can also find more information about the coils here: http://www.euromotoelectrics.com/product-p/boigncoil-k513.htm
The existing coil cover attaches just fine to these coils.
  • Henderson, NV
  • 1985 K100RT
« Reply #10 on: March 01, 2018, 03:47:12 PM »
The ground terminal for the core can be seen on the pictures in the other thread you have linked to.
It's on the opposite side on the rivet for the cover mounting bracket.
And while where at this subject.....beware that the 4V models also have orange tower coils, but they
are a very different animal......and have different connectors on low tension side.
Offline woodgeek
« Reply #11 on: March 01, 2018, 03:54:32 PM »
Oh god I’m blind! SMH
Thanks Inge![emoji106]
  • Henderson, NV
  • 1985 K100RT
