Author Topic: WTB ABS 1 mounting brackets  (Read 4772 times)
Offline Filmcamera
« on: November 14, 2016, 08:55:04 AM »
Hi
I am looking to reinstall the ABS that the PO had removed.
To do that I am looking for the mounting brackets etc to mount the modulators.
If anyone who has removed their ABS has these bits for sale that would be great.
The hoses would be a bonus if they are in good shape.
So basically looking at the attached diagram parts all of the parts on their except the actual modulator and the ABS sticker.
  • San Jose, Costa Rica
Poserbricker
Re: WTB ABS 1 mounting brackets
« Reply #1 on: November 14, 2016, 09:47:07 AM »
If you ride steep gravel roads, ABS might be problematic. Read the text on YouTube accompanying the following video.
« Reply #2 on: November 14, 2016, 11:50:24 AM »
good call putting the ABS back in.
don't (ever) use used hoses.  buy new braided or stock ones.
Offline Filmcamera
« Reply #3 on: November 14, 2016, 12:04:40 PM »
You are right, I was looking at a set of braided ones - at $240 not cheap but so be it.  I just want to make sure I can get the modulators mounted properly first.
Also the reason the PO took off the ABS was that the brain broke - I purchased a used one from a fellow motobricker. but just noticed the broken one calls itself AB02.5 whereas the replacement I brought is AB01.5 - anyone know if the two are compatible?
BTW I try very hard to avoid steep gravel with out without ABS!
Poserbricker
« Reply #4 on: November 14, 2016, 12:39:24 PM »
I have most of the parts from my '92 K100RS ABS which was working when I removed it.  Brain, bracket, modulators, hard lines.  The harness is still on the bike, but I might be able to remove it if you need it.
Make me an offer.
Offline Filmcamera
« Reply #5 on: November 14, 2016, 01:32:05 PM »
The Mighty Gryphon I sent you a PM.
Poserbricker
