MOTOBRICK MARKETPLACE
FS WTB WTT ~ Bikes ~ Parts ~ Gear
WTB ABS 1 mounting brackets
Topic: WTB ABS 1 mounting brackets (Read 4767 times)
Filmcamera
November 14, 2016, 08:55:04 AM »
Hi
I am looking to reinstall the ABS that the PO had removed.
To do that I am looking for the mounting brackets etc to mount the modulators.
If anyone who has removed their ABS has these bits for sale that would be great.
The hoses would be a bonus if they are in good shape.
So basically looking at the attached diagram parts all of the parts on their except the actual modulator and the ABS sticker.
San Jose, Costa Rica
1991 K100RS 16v ABS1, 2022 Triumph Tiger 900 Rally Pro
Laitch
Faster than a speeding pullet
Administrator
Re: WTB ABS 1 mounting brackets
Reply #1 on:
November 14, 2016, 09:47:07 AM »
Quote from: Filmcamera on November 14, 2016, 08:55:04 AM
If you ride steep gravel roads, ABS might be problematic. Read the text on YouTube accompanying the following video.
Along the Ridley in Vermont.
1995 K75 102,000 miles
K1300S
Reply #2 on:
November 14, 2016, 11:50:24 AM »
good call putting the ABS back in.
don't (ever) use used hoses. buy new braided or stock ones.
Filmcamera
Reply #3 on:
November 14, 2016, 12:04:40 PM »
You are right, I was looking at a set of braided ones - at $240 not cheap but so be it. I just want to make sure I can get the modulators mounted properly first.
Also the reason the PO took off the ABS was that the brain broke - I purchased a used one from a fellow motobricker. but just noticed the broken one calls itself AB02.5 whereas the replacement I brought is AB01.5 - anyone know if the two are compatible?
BTW I try very hard to avoid steep gravel with out without ABS!
The Mighty Gryphon
Administrator
Reply #4 on:
November 14, 2016, 12:39:24 PM »
I have most of the parts from my '92 K100RS ABS which was working when I removed it. Brain, bracket, modulators, hard lines. The harness is still on the bike, but I might be able to remove it if you need it.
Make me an offer.
In my garage in Marilla, NY
'91K100RS White/Blue
Filmcamera
Reply #5 on:
November 14, 2016, 01:32:05 PM »
The Mighty Gryphon I sent you a PM.
