Author Topic: Fuel problem?  (Read 15322 times)
Offline BlitzenGruv
Fuel problem?
« on: September 25, 2016, 08:12:47 PM »
Rode the brick today. Got maybe half a mile when it coughed and wouldn't take throttle.
Walked home and returned with tools. Pulled the line off the fuel rail, turned the key and it flowed for a second. Only way to keep it flowing is to crank the starter. I noticed one small glob of water in the fuel I collected, so I presume that this is the problem.
How can I drain the tank without burning up the starter?
  • Crossville, TN
Re: Fuel problem?
« Reply #1 on: September 25, 2016, 08:18:49 PM »
Easiest way would be to disconnect the starter (and isolate the wire end).
Re: Fuel problem?
« Reply #2 on: September 25, 2016, 08:38:36 PM »
try a bottle of Heet gas treatment.  I had the same problem (took a while to figure it out) and that solved it.
Re: Fuel problem?
« Reply #3 on: September 25, 2016, 08:46:23 PM »
Alcohol to the rescue! Ironic, isn't it.
  • 1995 K75 89,000 miles
Offline kennybobby
Re: Fuel problem?
« Reply #4 on: September 25, 2016, 09:55:10 PM »
You can drain the tank by pulling the line from the front end of the rail and pumping the fuel into a bucket.  To run the pump, make a jumper wire from the right side of fuse 4 to the left side of fuse 6.
Ridin' 87 K75S vin 1334,
Renchin' 86 75S vin 0061
Offline The Dude
Re: Fuel problem?
« Reply #5 on: September 25, 2016, 10:08:56 PM »
In moderation only...that's the water.
Syphon!
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline BlitzenGruv
Re: Fuel problem?
« Reply #6 on: September 26, 2016, 12:56:51 AM »
Now, THAT sounds like a plan, Thanks!
I shall do that, add some gas dry and a couple of gallons of fresh fuel.
I'm starting to miss the old Amal carbs, just open the drain plugs and the petcocks.  :eek:
  • Crossville, TN
Offline BlitzenGruv
Re: Fuel problem?
« Reply #7 on: September 27, 2016, 04:01:25 PM »
OK, so I pumped fuel out. Can't really see any water in what I collected. I added fresh fuel with gas dryer, still won't start. Actually it tries to start, just won't take throttle or stay running. Oddly enough, it won't even try with the "choke" fully on. If I crank it with the throttle fully open, then let off it tries harder to stay running but won't.
I have spark at the plugs, and they are wet when removed. All the fuses are good.
I thought I was through with working on bikes in parking lots when I bought this thing.
  • Crossville, TN
Re: Fuel problem?
« Reply #8 on: September 27, 2016, 04:15:56 PM »
Remove the fuel pump fuse No 6 Kraffstoppe and see if it starts, if it does test the temperature switch,
Re: Fuel problem?
« Reply #9 on: September 27, 2016, 07:14:46 PM »
If the plugs are wet with fuel, look toward ignition.
Offline BlitzenGruv
Re: Fuel problem?
« Reply #10 on: September 29, 2016, 06:24:32 AM »
Thanks for your responses.
Trailer reserved for Friday to get the bike home.
No time to chase wild geese. The K will sit until the BSA is back together and on the road.
  • Crossville, TN
Offline BlitzenGruv
Re: Fuel problem?
« Reply #11 on: October 09, 2016, 11:08:58 PM »
And where might that switch be located?  Absolutely no mention of this in the factory manual.
  • Crossville, TN
Re: Fuel problem?
« Reply #12 on: October 09, 2016, 11:50:14 PM »
It's sort of hard to see you need to remove the air intake snorkel. If you have small hands you might get to it otherwise you will have to remove the airbox.
Offline BlitzenGruv
Re: Fuel problem?
« Reply #13 on: October 10, 2016, 02:43:04 AM »
Thank you.
And what might a "normal" reading from the sensor be? I assume that it gives off an analog voltage somewhere.
Can I heat the thing to test it?
  • Crossville, TN
Re: Fuel problem?
« Reply #14 on: October 10, 2016, 04:53:05 AM »
There are posts on how to test. I presume that by you wanting to test it that it started with the fuse removed. If it is flooded and you remove the fuse and it starts, as it start to die you can ram the fuse back in and keep it running. It helps if you have two people. Also have a look at this very handy'
The Motobrick Technicial Library / K-Bike Flow Chart Beginning When You Hit The Switch ~ author   Bert Vogel
Offline BlitzenGruv
Re: Fuel problem?
« Reply #15 on: October 11, 2016, 04:18:36 AM »
Thanks Martin
I went out today and tried to start the bike. Fuse out, fuse in, it didn't even cough. I downloaded the flow chart and will start at square one. I already have new intake O rings and bushings to install, good time to check out everything.
  • Crossville, TN
Re: Fuel problem?
« Reply #16 on: October 11, 2016, 04:47:27 AM »
Be aware that it's for the 2V models, you have a 4V model......
all sensors, and the engine management system is different.
Re: Fuel problem?
« Reply #17 on: October 11, 2016, 06:22:42 AM »
+1 Flow chart won't work with your bike. If the plugs are wet and it still won't fire with the fuel pump fuse removed it is not the temperature sensor. When you crank the bike over do you have spark.
Offline BlitzenGruv
Re: Fuel problem?
« Reply #18 on: October 12, 2016, 06:28:26 AM »
Plugs look wet and black. The last time the engine ran it was running rich.
I cleaned them and watched in the dark. All are sparking. I do wonder about the recommendation for resistor plugs when resistor wires are also used. With any other ignition system this is a definite No-No.
In any case, if the flow chart does not apply I am at a loss where to start. The Motronic system depends on too many things being correct to be reliable. I don't know why they couldn't program the computer to interpolate enough data to run with one faulty sensor while giving an error indication, as automobile systems do.
I'll check compression while the plugs are out. It's getting slow at work, maybe I'll get laid off and have time to chase wild geese.
  • Crossville, TN
Re: Fuel problem?
« Reply #19 on: October 12, 2016, 06:42:55 AM »
I m not 100% sure but I believe a mates K100 RS just has resistor plugs fitted and not resistor leads. It doesn't make much sense having both. But in saying that a local BMW specialist  sold me resistor plugs for my 92 K75, I did try them could not see any benefit so I went back to normal plugs. Try looking up what plugs and leads suit your bike.
Re: Fuel problem?
« Reply #20 on: October 12, 2016, 10:02:21 AM »
Maybe your crankcase breather mod has a role in this. Checking the condition of that system is an option.
Offline BlitzenGruv
Re: Fuel problem?
« Reply #21 on: October 12, 2016, 04:16:26 PM »
I did that before I bought the plugs. The leads are original as far as I know, and are plainly marked as 5K. PO had non-resistor plugs in place. I didn't really notice any difference when I put the new plugs in.
  • Crossville, TN
Offline BlitzenGruv
Re: Fuel problem?
« Reply #22 on: October 12, 2016, 04:22:08 PM »
Always a possibility, but I thought that any leakage here would result in lean running.
While it's accessible I'll consider reverting to the stock breather hose. IF I can find one. All anybody seems to have available is for the 2-valve engine.
  • Crossville, TN
Re: Fuel problem?
« Reply #23 on: October 12, 2016, 04:32:31 PM »
Is the Motronic system the same as the K1100. If it is type in BMW K100 Motronic fault finding you get a few sites on fault finding the Moronic System Motronic system.
Re: Fuel problem?
« Reply #24 on: October 12, 2016, 05:58:22 PM »
It's the same generation (MA 2.1) as the early K11's (-93 year model).
I would have checked the air and water temp sensor and TPS, info you find in the K11ownersgroup forum.
