Author Topic: Fuel problem?  (Read 16808 times)
Offline BlitzenGruv
Re: Fuel problem?
« Reply #25 on: October 13, 2016, 02:39:11 AM »
Good call, Martin
I found a document with the fault codes and a procedure to test them. It's like the old check-engine codes, you can count the flashes to get the numbers.
  • Crossville, TN
Re: Fuel problem?
« Reply #26 on: October 13, 2016, 02:51:22 AM »
 :2thumbup: Keep at it you'll get there eventually.
Offline BlitzenGruv
Re: Fuel problem?
« Reply #27 on: October 14, 2016, 04:02:41 PM »
I came home today and saw this.
I hope she's praying for me to find the problem.
  • Crossville, TN
Re: Fuel problem?
« Reply #28 on: October 14, 2016, 04:15:17 PM »
 :2thumbup: Even Mother Nature is on your side. Or it could be a warning that your wife ( significant other ) is going to bite your head off if you don't get it going.   :dunno
Offline Elipten
Re: Fuel problem?
« Reply #29 on: October 14, 2016, 06:09:19 PM »
Lol
  • San Antonio, TX
  • 1990 K75RT
Offline BlitzenGruv
Re: Fuel problem?
« Reply #30 on: October 16, 2016, 11:18:18 PM »
All right, I've found a guide to reading K1100 error codes, assuming that they are the same Motronics codes for 4-V K100.
"Thereis a black 3 pin diagnostic connector on the left side of the bike above and to the left of the battery, you will needto remove the side cover to gain access. This connector will have a blue plastic weather protector connected to the open end. Pin #1 will have two Brown/Black wires, Pin #2 will have one Brown/White wire and Pin #3 one Brown/Green wire"
I'm not finding ANY connector on the left side of my battery, and nothing with these wire colors on the right side of the battery. Do I need to remove the petrol tank just to get to these connections?
  • Crossville, TN
Re: Fuel problem?
« Reply #31 on: October 16, 2016, 11:23:30 PM »
Can't help you with the location hopefully somebody will know. :dunno
Offline BlitzenGruv
Re: Fuel problem?
« Reply #32 on: October 17, 2016, 12:12:51 AM »
  • Crossville, TN
Re: Fuel problem?
« Reply #33 on: October 17, 2016, 05:38:52 AM »
Diagnostic connector, on the right side of the battery (this is on a 2V model, I assume you find yours in the same place):
