Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3515923 times)
Offline Jethroww
« Reply #4125 on: July 10, 2024, 05:42:38 AM »
Hi, 😱  No vibration like the old ones. Trying
to scare people in front of me. 👻
  • Ontario,Canada
  • BMW 1974 R75/6, BMW 1988 K75s 1989 BMW K100RS-SE Past: 1972 Norton Commando Combat
Offline MIbrick
« Reply #4126 on: July 23, 2024, 07:01:07 PM »
Not today, but over the last week:
* troubleshoot issue with temp gauge blowing Fuse #1 (many, many thanks to @TheMightyGriffon for his incredible support), including measuring resistance at temp sender (good)
* repaired my 'spare' temp gauge (center wire busted off ring terminal) and put that in place of the shorted temp gauge (fuse blowing problem solved)
* as long as the lower and belly fairings, fairing pads and seat were stripped, installed new light weight battery, pulled cylinder head cover and checked valve lash (all good!)
* changed all fluid and filters
* reinstalled all the various fiberglass bits and seat
* discovered the clutch pack was seized, so busted that loose doing the "5th gear + aggressively rocking" maneuver
* fresh gas + techron
* changed batteries in Fobo TPM thingies and aired up tires
Just waiting for this freaking rain to go away and I'll take her for a rip.
  • Michigan
  • 1986 K100RS (ohne Tragkorb)
« Reply #4127 on: September 22, 2024, 07:16:46 AM »
Yesterday, seasonal oil change on the Brick and the Boxer.
Offline Edward
« Reply #4128 on: January 18, 2025, 02:30:43 AM »
I repaired the constant ON the NEUTRAL LIGHT by replacing the PNP transistor BD370. The instrument cluster had to be dismantled to access the circuit board. I desoldered the OEM transistor, cleaned the three mounting points, and soldered the new one in place. Before reassembling the entire front end, I plugged in the instrument cluster for a successful test. The neutral light is on when in neutral. When I shifted it into first gear, the neutral light went out, and the same happened with the other gears. When the neutral light stays on, regardless of which gear is engaged, it is a serious safety issue. In any gear, the bike can start without pulling in the clutch. Sure, you can use the gear indicator, but mistakes can happen. If this happens to your K you'll have to dig deep to locate dead stock. When you solder, keep your iron no higher than 600 degrees f to reduced overheating the new transistor. Use a magnifying glass. (K75s 87 Original Owner)
  • Philadelphia, Pennsylvania USA
  • K75s 1987, MV Agusta Brutale 910s 2008 | Original owner
K75s 1987  | Original owner | RK BMW
MV Agusta Brutale 910s 2008 | Original owner | FBF
Offline stokester
« Reply #4129 on: January 19, 2025, 04:27:18 PM »
Good information to share, thanks.
Did you use a BD370 transistor or a suitable substitute?
  • Yorktown Virginia
Offline Edward
« Reply #4130 on: January 19, 2025, 05:34:57 PM »
You are welcome. I used a new deadstock PNP transistor BD370.
NOTE:
It's a known issue and its independent of the Transmission Switch (Gearbox Position Switch) indicating current gear positions. It's important not to get confused. The switch and any associated problems employs different troubleshooting methods. In my case the gear indicator showed each gear correctly which told me the transmission switch is functioning. The neutral light just would not go out no matter which gear selected. Replacing the transistor fixed that. While in the instrument cluster check for loose components. I found one weak solder joint so I fixed that.
Offline tweather
« Reply #4131 on: February 04, 2025, 09:03:41 PM »
I rode home my second brick! Chilly two hour ride from outside of Colorado Springs back home to Denver.
I’ve had a 95 K75RT since 2014. Fairings came off in like 2017.
As of today, I also own a 95 K1100LT which I rode home for less than $1k.
I need to stop buying and start selling vehicles.🙃
  • Denver, CO
  • 1994 BMW K75RT; 1995 K1100LT
Offline tweather
« Reply #4132 on: March 10, 2025, 02:41:54 AM »
Got in some Pirelli Angel GTs for my K1100LT. I’m not stoked about the idea of changing them but excited to get the new wheels on new tires. Ride On came in, too.
  • Denver, CO
Offline FTR
« Reply #4133 on: May 03, 2025, 01:25:42 PM »
Removed the old exhaust manifold studs which were rusted and very reluctant to come out. Used two lock nuts tightened against each other and heat to extract them.
Intending fitting some stainless ones eventually.
  • Hampsire UK
  • FTR1200, K100RS 83, MT09
1983 K100RS  Vin 0001126
Offline HuskerShaun
« Reply #4134 on: May 04, 2025, 09:43:09 AM »
Finished off re-mounting the handles onto the tail after removing the LT luggage rack and refastened the luggage racks. Still fighting my seat issue and started to work on installing some driving lights on custom mounts for under the mirrors. Hoping in '26 I can get a repaint done.
  • Garage of course... in Lexington, KY
  • 1993 K1100RS
Current Bikes: 1993 K11RS; 2015 R12GSA, '75 Moto Guzzi 850 T-3 Custom.
Past Bikes: '08 R12RT, '98K12RS, '94 K11LT, '85 K100RS, '72 Moto Guzzi Eldorado, '68 Guzzi Stornello, 71 Bultaco Alpina 350, Oset 24.0R (kids, Oset 16R (2) and Oset 12.5)
Offline HuskerShaun
« Reply #4135 on: June 04, 2025, 02:37:12 PM »
This last weekend, had some time. For now skipping some of my electrical upgrades to get her on the road. Fixed my sidepanels, got the new seat installed and aligned properly. This is my fourth k-bike (K100RS, K11LT, K12RS...now the '93 K11RS). So I've changed oil several times on these... for some reason I had it in my mind that I would pull the sump cover first... laughing at myself. What a mess. Despite having service records for the last 12 years and it showing the rear seal/o-ring had been done in the last 4-5 years... I might have that problem again. I'll see what accumulates underneath and make more plans. Cheers, Shaun
  • 1993 K1100RS
Offline Past-my-Prime
« Reply #4136 on: June 14, 2025, 05:57:54 PM »
I found that it is amazing what you can see if you just look.
No photos to post but short story: My bike suddenly got much louder. I was on a trip, and thought I must have blown the exhaust manifold or gasket or some such. I lived with it for the rest of that trip, and mentally prepared myself for manifold removal, broken studs, the whole shebang. I drove it a couple of times but usually just took Betty Blue (an F650 — enduro style - out while girding myself for the inevitable. Well yesterday, the inevitable happened, Betty Blue started squirting water from the water pump weep hole (the system on a F650 is pretty much the same as the K75: there is a common shaft with oil pump inside, water pump outside, and seals that like to leak). I’ve done the seal a few years ago, actually have done them on both bikes, and failure so soon is frustrating. So anyway, I don’t have the seal kit and had a longish rid planned for today. I decided to look at the exhaust manifold on Rocinante (my K75). Strange! One of the studs holding the front exhaust pipe to the head is completely missing! I looked in my pile of odds and ends and had a 10 cm long bolt that I had bought extra of for transmission removal. Incredibly, it threaded in perfectly! I screwed it in, and cut it off to an appropriate length with an angle grinder. Almost equally incredibly, I also found a suitable nut. I couldn’t believe my luck. An hours long anticipated job was fixed in 20 minutes. Bike is super quiet again. Whew!
I wonder how often the studs just back out like that, on their own, with no help?
Offline xcaret
« Reply #4137 on: July 07, 2025, 01:30:47 AM »
Well yesterday I removed everything that had been piled up on and around my flying brick for the last 3 years. I haven't ridden it for 3 years because my girlfriend was too heavy ( in my opinion) fortunately we broke up yesterday and I went back to my first love , that being motorcycles .  I felt so good again ,my garage stereo ( unused for 3 years too ) was playing my old meat loaf ,and Pink floyd songs on my still good  ( also after 3 years sitting ) flash drive. I swapped the battery out of my old Harley that also sat idle for 3 years and my K 75 RT fired right up.. That was yesterday , today I took both front and rear brake light switches trying to find why my brake light didn't light up.. Long story ,, After many happy hours of working on a bike again ,i found the bulb ( which lit up when connected to the terminals of my battery charger ) was an 1141 bulb, not the 1156 which is what the sig lights and brake light uses. I must have put it in and thought I had a working brake light years ago. So then I bravely ( I'm 78 years old and 170 pounds ) went around the block a few times . To my surprise It all came back in a few minutes. I went to a car wash and a 35 km cruise ,then stopped at Walmart and bought liquid Turtle Wax so I can wax it before heading out on a 100 or 200 km ride tomorrow .
Offline Edward
« Reply #4138 on: February 25, 2026, 08:06:34 PM »
In preparation for the end of this long ass winter season I'm dropping the pan to clean the screen and remount using Hylomar M. Bye bye 2025 drip. K75s 87
Offline frodef
  • 1986 K75C
« Reply #4139 on: April 18, 2026, 04:11:19 PM »
I mounted a $50 android auto screen off aliexpress. Seems to work fine, we'll see how long it lasts.
Offline Edward
« Reply #4140 on: May 24, 2026, 03:08:08 PM »
In the middle of replacing water and oil pump seals (kit from Euro Moto) and the drive gear (pitted shaft). Clockwork so far. Yes, the weep hole was plugged with debris. I repainted the cover with black appliance enamel, which tends to hold up well over time. I'll use trusty Hylomar M to seal it up.
Offline Edward
« Reply #4141 on: June 14, 2026, 08:23:48 PM »
Went for some Vermont vibes. Left early. Further work is needed on the cooling system. All ripped apart at the moment.
« Reply #4142 on: June 14, 2026, 10:57:05 PM »
So earlier this spring I had an unplanned 'get-off' as I got bit by the Snake(US421) in TN. I was able to right the bike and ride it out of the ditch(with some help) and back to the campground, but the damage was done.
After reviewing all my reasonable options I've decided to rebuild my '97LT(<56K miles) and put it back on the road. It has previously been damaged in a parking lot incident that left the main faring totaled, but mechanically and structurally was fine. Over the last few years I've stripped some parts off to keep my RT and other LT on the road.
Now at this point, I've previously sold the RT, and the remaining LT has totaled main fairing, damaged guards, damaged transmission, and over 126K miles. It is also showing signs of a leaking oil pump shaft seal(from the weep hole)
I picked up another LT for mainly the painted plastic parts(and everything else), this last week I got it all stripped down and broken down to basic parts, some of which  will be used on the rebuild of the '97, and what ever I have multiples of may show up for sale(yet to be determined) and damaged items to scrap.
Today I got the '95 up on the lift, ready for tear-down and inspection of parts to save/reuse on the '97.
Tomorrow I'm going to drop a battery in the '97, set a fuel tank on it and see if it fires up after setting 6yrs. I did a test today and it does turn over so that's in my favor..
Let the resurrection begin!!
« Reply #4143 on: June 18, 2026, 10:55:34 PM »
It's been a busy week. Re-installing parts that I have previously cannibalized off the bike.
I left off with testing the '97 for life.
I put a battery in it, placed a fuel tank on it and connected it all up. I turned the key, hit the button and it fired right up as if I had just ridden it an hour prior. No smoke, no hesitation, purred like a kitten.(ok a loud kitten with no Remus can on it...lol)  I would have thought for sure that it would have sputtered a bit after setting for 6yrs, but no, it started just fine.
Today, I got a lot of the front end(forks, handle bar and brakes) swapped and put back together. Rear MC changed out.
More wiring to complete, fuel+ to install, CC to install, Moto-lights to repair and install, EB lighting relays to install, aux fan switch to connect.
Pictures soon to come.
« Reply #4144 on: July 14, 2026, 10:31:54 PM »
Have made good progress the last 3 weeks.
Have all the accessories wired in, Fuel + connected and working, Motolights repaired and installed, Audiovox CC installed and tested, rear tail LED add-on's installed, aux fan switch installed.
Today I put 150 miles on it with Techron treated fuel. I'll run another full tank with Techron treatment before a TB balance, and oil change.
New tires should be received this week, mirrors to be painted yet.
Offline Edward
« Reply #4145 on: Today at 12:40:18 AM »
Well done Scott
