Author Topic: Need a new STARTER BUTTON  (Read 25054 times)
Offline bocutter Ed
Re: Need a new STARTER BUTTON
« Reply #25 on: September 10, 2018, 04:13:35 PM »
Ed is firing up the lathe.
No I'm not. I made 3 so there's 2 on the bench ...   :giggles
  • Toronto, Canada
Offline Northern Pike
« Reply #26 on: September 10, 2018, 10:16:19 PM »
Everybody check your start buttons. Light gravity might be affecting things today and bocutter Ed is firing up the lathe.
I just checked mine. Its still broken!
  • Canada
  • 1985 K100 RS
« Reply #27 on: September 10, 2018, 11:25:05 PM »
Bully!    :^)
  • Canada
  • 1985 K100 RS
Offline bocutter Ed
« Reply #28 on: September 11, 2018, 10:45:31 AM »
Looks like I may have to fire up the lathe after all. Three for johnny, and 1 for NPike.
It'll be another week before I lose my impediment though ...
  • Toronto, Canada
« Reply #29 on: September 11, 2018, 10:48:30 AM »
After that, will you be heading straight to the tanning booth for symmetry's sake?
Offline bocutter Ed
« Reply #30 on: September 11, 2018, 10:59:19 AM »
... thinking maybe vegetable dye at the tannery.
  • Toronto, Canada
« Reply #31 on: September 11, 2018, 01:58:49 PM »
Heard about your wrist from Rob when we met Darren in Youngstown.  We wondered where you were.  Hope you heel up soon.  How did the bike fare in the assault?
Offline bocutter Ed
« Reply #32 on: September 11, 2018, 03:03:21 PM »
Not too bad, I guess, considering I had 2 car lengths notice, @ ~50 kph, that he was pulling, from 0 kph, into my lane. Tagged the passenger door, then the curb ...
Windshield, both mirrors, center & right fairings, valve cover, crank cover.
Notice the white start button (staying on topic  :giggles ).
* IMG_3835.JPG (65.43 kB . 768x576 - viewed 628 times)
* IMG_3836.JPG (60.05 kB . 768x576 - viewed 609 times)
  • Toronto, Canada
« Reply #33 on: September 11, 2018, 03:20:17 PM »
Ouch!
  • Canada
  • 1985 K100 RS
« Reply #34 on: September 11, 2018, 06:13:38 PM »
Thank goodness the kitchen is safe!
« Reply #35 on: September 11, 2018, 06:21:33 PM »
Good luck at the tannery. If they have color swatches, please post them here.
« Reply #36 on: September 12, 2018, 01:57:28 PM »
Question for you, Ed:  What holds the white or green button in place?
My green button head has broken off and the spring flew away somewhere. The green shaft remains. What holds it in, and how do I get it out?
  • Canada
  • 1985 K100 RS
Offline bocutter Ed
« Reply #37 on: September 12, 2018, 08:34:14 PM »
There is a brass(?) contact pin coming up from the bottom. The pin's upper part is knurled and press fit into the green button's tube. The whole thing is held together like a hose on a hose barb, easy to push on but difficult to remove.
The assembly can got at by removing the screw under the start/kill switch. The start/kill assembly is held in that assembly with an 'e' clip. Careful  :yikes:, there are a couple of small springs you don't want to lose. I was going to drill down to the pin to punch it out, but the spring-loaded center punch split the head on the green shaft ... punched the pin out.
ps, too bad you lost the spring ...
  • Toronto, Canada
Offline bocutter Ed
« Reply #38 on: September 13, 2018, 11:40:49 AM »
Moto kitchen aka 'bwokx' stays up on the mezzanine until it's camping time. It's kept safe by the 2 top boxes when mounted ...
* IMG_3775.JPG (69.29 kB . 768x576 - viewed 574 times)
On the road to RustFest in Ottawa.
  • Toronto, Canada
Offline Monksvoice
« Reply #39 on: April 10, 2019, 12:20:24 PM »
I've decided to 3D print mine. Fired up Fusion 360 and after 13 different tries, (My original button broke, so I was missing a part.) I have a functioning button.
From here I'm going to cast a green one, as I don't trust PLA 3D printed plastic to hold up for long in the real world.
  • Upstate NY
  • 1986 K75, 1971R75
Offline Monksvoice
« Reply #40 on: April 10, 2019, 12:56:17 PM »
I'll smooth it out before casting it.
  • Upstate NY
  • 1986 K75, 1971R75
