brake pedal travel 1992 k75 rt
Topic: brake pedal travel 1992 k75 rt (Read 5963 times)
6.5
January 27, 2013, 09:45:46 PM »
Is there any way to reduce the brake pedal travel on my bike? Sure have to push it a long way until it grabs.
frankenduck
Adrninistrator
Re: brake pedal travel 1992 k75 rt
Reply #1 on:
January 27, 2013, 10:06:12 PM »
Yes, but why?
It's not a Harley.
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
wmax351
Reply #2 on:
January 27, 2013, 10:43:53 PM »
There is a bolt between the pedal and the master cylinder. You can tighten it up a bit, but you want some dead zone. The rear brakes can be vague, so it is good to have some more travel.
Albuquerque, NM
91 BMW K75 Standard, 98 Moto Guzzi California EV
Bikes:
frankenduck
Adrninistrator
Reply #3 on:
January 27, 2013, 10:54:16 PM »
Even loosely adjusted it isn't that hard to lock up a rear disc on a K bike. Why anyone would want to make it more tightly adjusted is beyond me. :dunno2:
It's also helpful to have some play in there to illuminate your brake light when you're slowing without really braking.
If you're using your rear brake as your primary brake then you're doing it wrong.
And be careful about getting it too tight. If you do then the piston can get stuck on the set screw in the master cylinder.
New to K bikes?
Click here.
Click here.
Chaos
Administrator
Mars needs women!
Reply #4 on:
January 27, 2013, 11:04:10 PM »
Have you tried bleeding it?
sw ohio
1987 K75S VIN 0231
6.5
Reply #5 on:
January 28, 2013, 05:41:32 PM »
Thanks all
