Author Topic: brake pedal travel 1992 k75 rt  (Read 5027 times)
Offline 6.5
« on: January 27, 2013, 09:45:46 PM »
Is there any way to reduce the brake pedal travel on my bike? Sure have to push it a long way until it grabs.
Re: brake pedal travel 1992 k75 rt
« Reply #1 on: January 27, 2013, 10:06:12 PM »
Yes, but why?
It's not a Harley.
Offline wmax351
« Reply #2 on: January 27, 2013, 10:43:53 PM »
There is a bolt between the pedal and the master cylinder. You can tighten it up a bit, but you want some dead zone. The rear brakes can be vague, so it is good to have some more travel.
  • Albuquerque, NM
Bikes:
« Reply #3 on: January 27, 2013, 10:54:16 PM »
Even loosely adjusted it isn't that hard to lock up a rear disc on a K bike. Why anyone would want to make it more tightly adjusted is beyond me. :dunno2:
It's also helpful to have some play in there to illuminate your brake light when you're slowing without really braking.
If you're using your rear brake as your primary brake then you're doing it wrong.
And be careful about getting it too tight.  If you do then the piston can get stuck on the set screw in the master cylinder.
« Reply #4 on: January 27, 2013, 11:04:10 PM »
Have you tried bleeding it?
Offline 6.5
« Reply #5 on: January 28, 2013, 05:41:32 PM »
Thanks all
