Author Topic: Hi and Lo beam good, but no Hi flash...K100RS4V  (Read 3504 times)
Offline moynistan
  • Ignorance is bliss...
« on: September 16, 2012, 08:31:03 PM »
I disassmbled the switchgear per Lieberry instruction.  Everything is clean, and wiring/soldering looks great. I can see what is happening when I move the switch and cannot understand why the Hi beam won't flash... :dunno2:
Any takers?
Kevin Moynihan
1958 R26
2001 R1150GS
1991 K100RS4V
Re: Hi and Lo beam good, but no Hi flash...K100RS4V
« Reply #1 on: September 16, 2012, 08:37:39 PM »
Do you got power on the green/blue wire? If not, check the connector under the tank.
Inge K.
Offline moynistan
« Reply #2 on: September 17, 2012, 12:24:34 PM »
Thanks, obviously I'm pretty limited in my understanding of electrical matters, I appreciate your patience with a noob.
SOLVED:  missing micro screw on hi low beam switch replaced and cleaned contacts, reconnected and good to go.
Kevin Moynihan
1958 R26
2001 R1150GS
1991 K100RS4V
