Repair Guidance
Hi and Lo beam good, but no Hi flash...K100RS4V
Topic: Hi and Lo beam good, but no Hi flash...K100RS4V (Read 3506 times)
moynistan
Motobrick Curious
Ignorance is bliss...
September 16, 2012, 08:31:03 PM »
I disassmbled the switchgear per Lieberry instruction. Everything is clean, and wiring/soldering looks great. I can see what is happening when I move the switch and cannot understand why the Hi beam won't flash... :dunno2:
Any takers?
Kevin Moynihan
1958 R26
2001 R1150GS
1991 K100RS4V
Inge K.
Re: Hi and Lo beam good, but no Hi flash...K100RS4V
Reply #1 on:
September 16, 2012, 08:37:39 PM »
Do you got power on the green/blue wire? If not, check the connector under the tank.
Inge K.
Norway
moynistan
Motobrick Curious
Reply #2 on:
September 17, 2012, 12:24:34 PM »
Thanks, obviously I'm pretty limited in my understanding of electrical matters, I appreciate your patience with a noob.
SOLVED: missing micro screw on hi low beam switch replaced and cleaned contacts, reconnected and good to go.
Kevin Moynihan
1958 R26
2001 R1150GS
1991 K100RS4V
