Author Topic: Water/oil pump seal question  (Read 71699 times)
Offline conybeare
  • Conybrick
« on: March 08, 2012, 10:29:21 PM »
I am getting ready to rebuild the water/oil pump. The slip-ring seal that I ordered looks different than what I expected. Based on the IBMWR article (http://www.ibmwr.org/ktech/water-oil-pump-rebuild2.shtml), I was expecting the seal to have the "blue goo" or blue stripe on the outside and inside. Instead it only has it on the outside. Here it is:
Part no. 11411741870
Without that sealant or ring on the inside, how does the seal keep water from traveling along the shaft to the oil side (and through the backside of the oil seal)? Has anyone installed one of these? This was the only seal the the Max BMW parts fiche would give me for the K75S, so I'm thinking maybe it's just a newer style. I'm just confused about how it works and wanted to see if I'm missing something...
Thanks a bunch.
  • Saint Paul MN
Nothing :o
Previous: 2004 R1100S, 2009 Yamaha FZ6,1990 K75S, 1986 K75C, 1984 Honda VT500 Ascot, 1981 Suzuki GS250T
Re: Water/oil pump seal question
« Reply #1 on: March 09, 2012, 03:44:40 AM »
A bit confusing this issue......
The seal used at the ibmwr page has a higher part # than yours, so I assume it`s newer.
With a part# search at max bmw, no K75 models are shown.
The service bulletin (pdf file at same page) says all 75, 100, 1100 models.
It also was a change at pump housing from 01/90, don`t know if that makes any difference.
(Don`t think so, since K100 models also after that date is shown).
Max BMW part# search.
Inge K.
Rick G
« Reply #2 on: March 09, 2012, 05:02:57 AM »
I have used that seal twice and no problem so far and that was 3 months ago
Offline lukeman
« Reply #3 on: March 12, 2012, 02:37:50 PM »
Yeah I think they changed the part again because I did my seal a few months back and got the same part in the picture.  Seems to be working well so far for me.  The guide is pretty handy.
Offline conybeare
  • Conybrick
« Reply #4 on: March 12, 2012, 03:07:54 PM »
OK, thanks for the input everyone. Still not sure who it's supposed to seal, but sounds it like will work  :bmwsmile
  • Saint Paul MN
Nothing :o
Offline lukeman
« Reply #5 on: March 15, 2012, 01:12:10 PM »
What do you guys use to seal the pump to the engine and the water cover to the pump housing?  I've done it twice and the damn thing is still leaking radiator fluid and oil from where I used a liquid gasket product.  Do you let it setup over night?  Its driving me nuts that my K100 is dripping fluids.
« Reply #6 on: March 15, 2012, 01:26:13 PM »
If you read the instructions on the tube for some of those products many of them recommend only tightening it loosely at first, letting it sit for 30 minutes to set a bit and then tightening the bolts.
Skeezer
« Reply #7 on: April 09, 2012, 11:27:48 PM »
So I'm Guessing this is the fix for Oil and Coolant leaking out of the weep hole in bottom of the motor?
 :confused:Checking the posted link above it states that the updated Seal must be used in conjuction with the Updated spacer and impeller. Is this correct?
awshucks
« Reply #8 on: April 10, 2012, 06:11:51 PM »
Yeah, enquiring minds want to know.  I have the problem of a drippy water pump and would like to know the cheapest way 0ut?
« Reply #9 on: April 10, 2012, 10:40:26 PM »
ConyB, in responce to your initial question about how the shaft seals.
The part in your picture is only 1/2 of the assembly. A typical shaft seal is 2 pieces. The part you are showing is the fixed half. The part you aren't showing is the rotating half.
It's the rotating half that seals the shaft and also seals against the face(part facing down in your picture) thus keeping the water in.
1957 K1100LT 0302044 (R.I.P.)
Skeezer
« Reply #10 on: April 12, 2012, 05:57:37 PM »
Another question. Do you need to remove the pump our can the seals be replaced by removing the cover and doing the repair on the Bike?
Rick G
« Reply #11 on: April 12, 2012, 08:31:57 PM »
As far as BMW is concerned yes but I have been taking 3mm from the inside face on the boss of the cast impeller and it all fits together just fine without the pressed steel impeller.  Getting rid of rust from the cast impeller I just soak it for a few days in a 10% solution of molassis.
Offline motodude
« Reply #12 on: April 12, 2012, 08:50:18 PM »
Gotta love this list!
Tom
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
Offline conybeare
  • Conybrick
« Reply #13 on: April 13, 2012, 01:47:08 AM »
I believe that picture depicts the entire seal. The rotating half is the inner portion. If you were to push the inner portion from behind the seal (as pictured) you could see it better. It also rotates. The outer piece has the blue stripe.
  • Saint Paul MN
Nothing :o
Offline conybeare
  • Conybrick
« Reply #14 on: April 13, 2012, 01:54:35 AM »
Pump must be removed. The shaft must be removed to replace the seals, and then to reinstall the shaft you have to hold it from the rear with a hex wrench as you draw the shaft back through the seals, like so (starts at 3:45):
Not a big deal though, removing the pump is only about 4% more work compared to the rest of the project.
  • Saint Paul MN
Nothing :o
Skeezer
« Reply #15 on: April 13, 2012, 10:24:43 AM »
Thank you VERY MUCH. I will tackle this job on the week end. If my local BMW Dealer has the parts( doubtful)
Offline lukeman
« Reply #16 on: April 13, 2012, 02:49:15 PM »
Not sure if you are getting more than just the seals, but most people recommend getting the shaft which is the $$$ part...
This is the list that I used with the shaft and updated rotor.
For reference if anyone was thinking about doing it:
12311460853 Screw - M8x22 $1.39
11411461173 Rotor $14.26
11511464902 Spacer Bushing - $7.65
11411460329 Shaft Seal - $6.60
11411741870 Slip-Ring Seal - $21.95
11111460392 O-Ring - $1.34
11411460328 O-Ring - $0.91
11411461183 Shaft - $121.06
Offline ReneZ
« Reply #17 on: April 18, 2012, 06:08:19 PM »
You don't necessarily need a shaft. The earlier seals were running directly on the shaft (like the oil seal still does). However the sealing part is part of the new type mechanical seal. It has the larger cup (with the blue sealant) which seals into the house and the other end of the seal seals on the shaft (look at the picture in the earlier post - you can see the internal sealing ring in there). These are 'stationary seals' i.e, the don't move on the shaft so an affected shaft can be repaired by using a filler in way of pitting if the location where the seal sits on the shaft is affected, but please appreciate that it is not the locations where the earlier type water seals were running on the shaft and therefore where the wear would show.
Greetings, Rene
BMW K100 - 1984
BMW K1200GT - 2003
Offline GasStation
  • 93 K75S Mystic Red
Slip-ring seal
« Reply #18 on: April 19, 2012, 12:34:37 AM »
What are the chances of wasting a slip-ring seal on a pump rebuild. A mechanic at my dealer said that unless I had done this before, I would probably end up trashing two to three slip-ring seals.
I watched the video posted a few posts before and it certainly does not appear too complicated.
Are they tooting their own horn or is this a statistically expensive job for the novice?
I was even thinking of buying the "drift" or BMW press-in bushing. I can always remove the pump assembly and drop it off at the dealer, but they won't warranty anything since they are not reinstalling entirely.
93 K75S Mystic Red
IBA #9469
« Reply #19 on: April 19, 2012, 03:31:22 AM »
That was interesting information, I thought it was used mechanical seal on all models
from the very start of production.
The change must have been quite early, you know what year this was changed?
Just curious.
Inge K.
Offline lukeman
Re: Slip-ring seal
« Reply #20 on: April 19, 2012, 02:33:31 PM »
I don't think you will have any issues.  I was pretty nervous about busting the ceramic seal, but using the method in the video to tighten it worked like a charm.
Offline sh00ter
« Reply #21 on: April 19, 2012, 02:59:06 PM »
Am interested to hear how/if you get it to seal up; please post your technique & what goo you used for the seal thx!
'94 1100 RS
Re: Slip-ring seal
« Reply #22 on: April 19, 2012, 03:29:01 PM »
Its not bad at all. Just follow the directions, and don't force anything. Be careful of the direction on the oil seal. The instructions are kinda ambiguous (I had it reversed the first time I rebuilt it.). The Ceramic seal was easy, just use the bolt and a washer/spacer.
http://permatex.com/products/Automotive/automotive_gasketing/anaerobic_gasket_makers/Permatex_Anaerobic_Gasket_Maker_b.htm
http://permatex.com/documents/tds/Automotive/51813.pdf
I used permatex anaerobic flange sealant and gasket maker. It is a hardening gasket maker, that is great on well machined surfaces. Clean the surfaces really well, apply a thin coat to both parts, and tighten down. Wipe off excess. It only hardens when compressed or held away from air, and is oil soluble.
Offline GasStation
« Reply #23 on: April 20, 2012, 05:38:54 PM »
What is ceramic seal? Is that the same as "slip-ring" seal?
I ask as I thought there was silicone in there.
93 K75S Mystic Red
IBA #9469
« Reply #24 on: April 20, 2012, 07:02:03 PM »
That is correct.
