Author Topic: BARN FIND! 85 K100 13K  (Read 12195 times)
Offline Atabeach
« on: October 24, 2025, 10:11:57 PM »
...now I have 3. Ok sooo where do I start? the bike doesn't run...probably hasn't for years. Turns over, no obvious dents or damage....rolls real nice not much else.
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ; FYK! 2002 Harley Dyna, & my favorite 2006 Vespa LX150!
Re: BARN FIND! 85 K100 13K
« Reply #1 on: October 25, 2025, 09:13:55 AM »
You remove and thoroughly clean the fuel tank, replace the fuel hoses in the tank and replace the fuel filter, and replace the fuel pump's vibration damper if it doesn't grip the pump. Clean or replace the pump's screen also. Using DeoxIT D5, you clean every electrical connector—including the LE-Jetronic and the ignition control unit plugs, clean all terminals connected to the plate—and the plate itself—that is the main ground connection under the frame backbone. Clean the battery ground connection attached to the transmission, the battery terminals and connections, the alternator terminals and connectors, and the starter connections. Check for electrical continuity from the fuel injection relay to the fuel pump.
When you're finished with that, you can try to start it again.   :laughing4-giggles:  Let us know when that happens.
Offline Atabeach
« Reply #2 on: October 25, 2025, 08:51:01 PM »
Thanks Laitch! I didn’t think of all the electric connections…Looking forward…wish me luck, I’m going to need it. 😳😳 along with parts…lots of parts😜
  • Ponte Vedra Fl
Offline Atabeach
« Reply #3 on: October 27, 2025, 09:27:54 PM »
Some things I’ve never seen…also the seat has the handles built in to seat!
Fellas…I am going to try to keep this bike as unmolested and original as possible. I am already seeing some “different “ things. Please inform me of any KNOWN parts that are exclusive to this bike. It will save me some $, time and aggravation 😳 Thanks guys!
  • Ponte Vedra Fl
Offline Atabeach
« Reply #4 on: November 04, 2025, 10:15:55 AM »
Ok Fellas going through the brakes..Totally dis assembled front brake system, ran cleaner and air through old lines and "exercised"  the calipers. Took apart the front master.... it bench checked ok...installed everything.... bled nicely...no leaks....Not getting any real pressure. There doesn't seem to be any REAL pressure building. TIA
  • Ponte Vedra Fl
« Reply #5 on: November 04, 2025, 10:56:20 AM »
Describe your bench checking process. Describe "no REAL pressure." What's the unreal pressure feel like?
Offline Atabeach
« Reply #6 on: November 04, 2025, 11:18:08 AM »
Bench check was placing unit a bench vice. First with no oil ..,There was pressure and then some suction when squeezing the piston. Did the same with oil looked like it was squirting nicely. After bleeding the brakes and getting all of the air out,  when applying 10 or more “pumps“the bleed valve dribbles… normal pressure would squirt! Sort of the difference between a 16-year-old and well…..
I will be changing the lines when MOTOBINS UK “figures out” the tariffs..  their quote, not mine
  • Ponte Vedra Fl
« Reply #7 on: November 04, 2025, 11:31:25 AM »
Let's use artery and vein instead. We're not want to stimulate onanism here.
You've witnessed the bleed valve on this ancient caliper squirting?
Offline Atabeach
« Reply #8 on: November 04, 2025, 11:34:35 AM »
Latch… not the one on the bike. I ordered a new slave cylinder. If there is no leak why isn’t she building any pressure?
  • Ponte Vedra Fl
« Reply #9 on: November 04, 2025, 12:35:38 PM »
You're all over the map here. By slave cylinder, do you mean the brake (master cylinder)? Slavery is not part of Classic Brick history. The master cylinder will not develop pressure if fluid is flowing from one side of the piston to the other without going into the brake line. I'm getting the feeling the problem occurred during reassembly after cleaning. Revisit the piston and verify the placement of parts.
Offline Atabeach
« Reply #10 on: November 04, 2025, 12:57:58 PM »
To be clear I did not remove the cylinder from its  housing. I will now. It didn’t leak, therefore I assumed it would provide decent  pressure. Both holes in the reservoir appear to be clear.
  • Ponte Vedra Fl
« Reply #11 on: November 04, 2025, 02:44:26 PM »
So do I have this correct? You didn't totally disassemble the brake system, and you didn't bleed the brakes through the caliper. You've not seen the caliper on the bike squirt fluid from its bleed valve. You've ordered a replacement front master cylinder.
Which part are you calling a slave cylinder?
Offline Atabeach
« Reply #12 on: November 06, 2025, 01:33:49 PM »
Pure Genius. $20. Thanks to all whom have come before!
  • Ponte Vedra Fl
« Reply #13 on: November 06, 2025, 01:37:10 PM »
 103123
Offline Atabeach
« Reply #14 on: November 08, 2025, 07:15:41 AM »
Necessity, is the mother of invention, windshield arm
. Ok sooo needs …..before I peruse Fleabay
 Air intake thingy ( photo )
 Battery hold down
 Anyone know what touch up paint is close?
 LED lights for cluster
  • Ponte Vedra Fl
Offline Past-my-Prime
« Reply #15 on: November 10, 2025, 09:30:52 AM »
Brake fluid . . . it's a bummer on a beemer.
Offline Atabeach
« Reply #16 on: November 12, 2025, 09:50:06 PM »
I stumbled onto a Gem! No vent hose! FYK!!!  …IYKYK….and there is the hazard switch connector, they thought of everything!
  • Ponte Vedra Fl
Offline Kaos
  • Vlad the Extractor
« Reply #17 on: November 13, 2025, 02:42:03 PM »
The colour code is Baja red metallic by the looks of it. Bmw paint code 174.
Any good car paint shop could mix it for you.
Also where are all these magical barns? This isnt the first "barnfind" i see here.
I need findbarn..
  • Basically Everywhere
Offline Atabeach
« Reply #18 on: November 14, 2025, 06:09:49 PM »
Ok more discoveries. There is a grease fitting on the steering column.  Also, this is an early bike March 1984.
  • Ponte Vedra Fl
Offline Atabeach
« Reply #19 on: February 27, 2026, 12:13:04 PM »
Ok fellows I’m having a hell of a time matching paint. 1985 k100 Color # is 575 lava red. CLOSE IS OK !! I would like to leave this bike as original as possible. The paint is ok except chipping and the radiator guard. Also… Will all LT top luggage racks fit a 1985? The seat is different on a 85 with the handles mounted directly into seat. Again, I would like to keep her unmolested as possible. This is my daily driver. TIA
  • Ponte Vedra Fl
Offline Atabeach
« Reply #20 on: February 27, 2026, 12:53:01 PM »
….also does anyone know where to get these caps? Apparently mine flew off they were so old! Ironically the bike is running fine…
  • Ponte Vedra Fl
« Reply #21 on: February 27, 2026, 03:36:14 PM »
I know them as vacuum caps. BMW calls them protection caps. Measure the outside diameter of the port, size them for a friction fit and get them from an auto parts store.
