Author Topic: Clutch cable  (Read 9115 times)
Offline jimjimini
Clutch cable
« on: April 08, 2025, 07:35:36 AM »
Hi all I have a 1986 k100rs that I am currently restoring. The clutch cable nipple has started popping out at the lever end is this because the cable is on the limit of it`s stretch or is the lever worn ?  Cheers
Offline triplek
Re: Clutch cable
« Reply #1 on: April 08, 2025, 08:34:55 AM »
Do you have an image of the cable at the problem area?
"Every time you criticize my grammar, I like you a little bit fewer."
1995 K75 RTP, 1995 K75 RT, 1993 K75, two K75 frames, 1 fully assembled engine from airbox to exhaust tip and enough fairings and  parts to build another K. Soon.  ;)
Offline jimjimini
Re: Clutch cable
« Reply #2 on: April 08, 2025, 09:00:25 AM »
* IMG_1455.JPG (37.74 kB . 768x576 - viewed 758 times)
* IMG_1456.JPG (23.24 kB . 768x576 - viewed 668 times)
Re: Clutch cable
« Reply #3 on: April 08, 2025, 10:13:12 AM »
The metal nub end of the cable fits into this barrel; the barrel fits into the clutch hand lever. You've lost the barrel. The barrel (nipple holder)/hand lever assembly should be greased regularly during riding season. The photo below is from the Max BMW parts fiche in New Hampshire. The part is found in the Steering section's cable diagram.
Offline jimjimini
Re: Clutch cable
« Reply #4 on: April 08, 2025, 10:58:39 AM »
How the hell has that happened  Thought it didn`t look right   Cheers
Re: Clutch cable
« Reply #5 on: April 08, 2025, 11:37:27 AM »
Let's just call it Karma and move on.  :laughing4-giggles:
Re: Clutch cable
« Reply #6 on: April 08, 2025, 12:18:07 PM »
Somebody was messing with the clutch and forgot to put it back. That part does not just fall out and escape.
+1 on keeping it greased.
Re: Clutch cable
« Reply #7 on: April 09, 2025, 05:55:16 AM »
and +1 to carry an extra....
1995 K1100LT 0302044 (R.I.P)
Offline jimjimini
Re: Clutch cable
« Reply #8 on: April 12, 2025, 10:56:01 AM »
Mystery over I found a bent c washer. I think this was jammed behind the nipple and had fallen out. Glad it happened at home.
Re: Clutch cable
« Reply #9 on: April 12, 2025, 02:01:52 PM »
No c-washer in the assembly of my Brick nor one in the parts list. What's your decision for a remedy?
Offline jimjimini
Re: Clutch cable
« Reply #10 on: April 13, 2025, 03:31:45 AM »
It was a bodge me thinks. i have now purchased the proper parts    Cheers
