Clutch cable
Topic: Clutch cable (Read 9487 times)
jimjimini
Curious
Clutch cable
April 08, 2025, 07:35:36 AM »
Hi all I have a 1986 k100rs that I am currently restoring. The clutch cable nipple has started popping out at the lever end is this because the cable is on the limit of it`s stretch or is the lever worn ? Cheers
triplek
^ Motobrick Curious
Re: Clutch cable
Reply #1 on:
April 08, 2025, 08:34:55 AM »
Do you have an image of the cable at the problem area?
"Every time you criticize my grammar, I like you a little bit fewer."
1995 K75 RTP, 1995 K75 RT, 1993 K75, two K75 frames, 1 fully assembled engine from airbox to exhaust tip and enough fairings and parts to build another K. Soon. ;)
jimjimini
Curious
Re: Clutch cable
Reply #2 on:
April 08, 2025, 09:00:25 AM »
(37.74 kB . 768x576 - viewed 810 times)
(23.24 kB . 768x576 - viewed 703 times)
Laitch
Faster than a speeding pullet
Administrator
Re: Clutch cable
Reply #3 on:
April 08, 2025, 10:13:12 AM »
The metal nub end of the cable fits into this barrel; the barrel fits into the clutch hand lever. You've lost the barrel. The barrel (nipple holder)/hand lever assembly should be greased regularly during riding season. The photo below is from the
Max BMW parts fiche
in New Hampshire. The part is found in the Steering section's cable diagram.
Along the Ridley in Vermont.
1995 K75 102,000 miles
Agree x 1
View List
jimjimini
Curious
Re: Clutch cable
Reply #4 on:
April 08, 2025, 10:58:39 AM »
How the hell has that happened Thought it didn`t look right Cheers
Laitch
Administrator
Re: Clutch cable
Reply #5 on:
April 08, 2025, 11:37:27 AM »
Quote from: jimjimini on April 08, 2025, 10:58:39 AM
Let's just call it
Karma
and move on.
frankenduck
Adrninistrator
Re: Clutch cable
Reply #6 on:
April 08, 2025, 12:18:07 PM »
Somebody was messing with the clutch and forgot to put it back. That part does not just fall out and escape.
+1 on keeping it greased.
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
Scott_
Administrator
Re: Clutch cable
Reply #7 on:
April 09, 2025, 05:55:16 AM »
and +1 to carry an extra....
My Garage
jimjimini
Curious
Re: Clutch cable
Reply #8 on:
April 12, 2025, 10:56:01 AM »
Mystery over I found a bent c washer. I think this was jammed behind the nipple and had fallen out. Glad it happened at home.
Laitch
Administrator
Re: Clutch cable
Reply #9 on:
April 12, 2025, 02:01:52 PM »
No c-washer in the assembly of my Brick nor one in the parts list. What's your decision for a remedy?
jimjimini
Curious
Re: Clutch cable
Reply #10 on:
April 13, 2025, 03:31:45 AM »
It was a bodge me thinks. i have now purchased the proper parts Cheers
Clutch cable
