Bob to cheer you up a piccie of a K100S. Dream and you can sometimes make it so.
BMW K100s 2.jpg (107.4 kB . 768x576 - viewed 1886 times)
Thank you for the motivation, Martin. That's actually the color I had in mind!
I was out looking at the RS this morning and I'm getting more and more excited to get it back on the road. I did a real basic look over and here's what I've found so far...
- Missing battery (no surprise)
- Missing Jetronic controller (a surprise)
- Shifts up thru the gears ok, at least standing still
- No ignition switch that I can find, so maybe the PO just hard wired it? No, that would leave the lights on. Hmmm don't know.
- The little "dashboard" where the ignition switch would normally be mounted is missing
- Some missing bolts and screws
- Missing the gas cap assembly
- Fuel pump is present (was supposedly pulled) but wires are disconnected so maybe the bad pump from the other bike was put in there? Fuel filter is missing.
- It has the old style tank, with single rear mounting bolt, same as my other bike
- Flat front tire
- Front wheel hangs on rotation (warped rotors?)
- Back tire rotates fine
- Front break supposedly works but you have to pull it in completely to the handlebar if it does.
- Starter button broken
- Throttle extremely hard to turn
- Right mirror/signal not on the bike. I have it. It's missing one of the clips and the connector on the bike end was ripped off/missing
- Clutch appears to work
