Author Topic: Wear Shock!  (Read 27091 times)
Offline Soggz
Wear Shock!
« on: September 26, 2019, 06:06:19 AM »
Ok guys.
At the start of this year, as some may know, I had some new a spline set welded onto my prop, as the splines were funked!
Today, I disassembled the rear end just to see how much wear was evident at 1050 miles, from when I got the bike on the road from 1st June.
The splines were greased with moly grease, and even moly powder dust was added.
The final drive splines weren’t great, but usable. Here’s the results.
I have ridden the bike fairly hard, so it’s probably a bit my fault and a bit of mixing new spline with old. On reassembly, I am trying the Chris Harris silicone plug method to help relieve lubrications creep.
I also mixed a stronger recipe of grease and moly powder, this time.
  • Down in Selwood Forest
Re: Wear Shock!
« Reply #1 on: September 26, 2019, 06:57:22 AM »
Yep, that pretty much covers it.
The new female half does you no more good than the old one without a matching new set of male splines. Your "contact area" is only as good as the available surface area of the male splines(and matching female half), which in your case is not very good.(though others have been worse)
Now if you were to put a new male spline into what remains of the shaft, you will soon wear out the male one to match the male you removed(as you have damage the contact area of the female half).......
Your only real true resolution is to replace both, at the same time.
Offline Soggz
Re: Wear Shock!
« Reply #2 on: September 26, 2019, 07:04:29 AM »
Yes. A lesson, learnt.But I am surprised on the wear in such a short time.
So how many miles do you think is left between the two?
Offline Soggz
Re: Wear Shock!
« Reply #3 on: September 26, 2019, 07:32:24 AM »
Just as a comparison. New ones after 1050 miles, and the old one as when I first got the bike.
Offline Soggz
Re: Wear Shock!
« Reply #4 on: September 26, 2019, 09:50:09 AM »
i am proficient in american english... as learnt at the university of cambridge... and practiced acrosst all corners of this flat earth...
just ride... getts a lorry in que and not worry about it...
lol. I’m not worried, Johnny. I have a AA breakdown card. It was just a bit of an experiment to highlight the wear factor of new mixed with old splines. Hope this is helpful to people. It would be nice to get a better rear drive, as I can get the drive shaft splines welded on for free.
Offline Soggz
Re: Wear Shock!
« Reply #5 on: September 26, 2019, 10:47:31 AM »
Not quite sure what you mean, Johnny. You ever do English at school?
Re: Wear Shock!
« Reply #6 on: September 26, 2019, 11:29:41 AM »
think of the problem as a phillips head screw.
you try to get it out with a phillips head screw driver that is too small.  it strips out the head of the screw a bit.  so you get a new screw, but use the same too small driver.  guess what will happen again?  yep, ya strip out another screw.
Offline Soggz
Re: Wear Shock!
« Reply #7 on: September 26, 2019, 12:05:48 PM »
Yes. Good example. Finding a newer rear final drive is a bit of a problem. Anyone know of one?
Offline volador
  • NEEDS MORE CHROME
Re: Wear Shock!
« Reply #8 on: September 26, 2019, 12:29:57 PM »
Should ask Past-my-Prime ?  http://www.motobrick.com/index.php/topic,12817.0.html
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline volador
  • NEEDS MORE CHROME
Re: Wear Shock!
« Reply #9 on: September 26, 2019, 12:44:42 PM »
AS an experiment try using a grease like Staburags NBU 30 PTM.
See if next 1000 miles yields different result?
  • NYC NY
Offline Soggz
Re: Wear Shock!
« Reply #10 on: September 26, 2019, 01:54:13 PM »
I think yours is the model with more splines than mine.
Offline volador
  • NEEDS MORE CHROME
Re: Wear Shock!
« Reply #11 on: September 26, 2019, 01:59:34 PM »
Yours, his, minez, I see Z=20 splines all around
PM sent
  • NYC NY
Offline Soggz
Re: Wear Shock!
« Reply #12 on: September 26, 2019, 02:04:43 PM »
PM sent
yes, sorry. I was distracted.
Apologies.
I see what you mean. I’m guessing I have a few more miles left then before stranding will happen?
Offline volador
  • NEEDS MORE CHROME
Re: Wear Shock!
« Reply #13 on: September 26, 2019, 02:23:12 PM »
10k +
  • NYC NY
Offline Soggz
Re: Wear Shock!
« Reply #14 on: September 26, 2019, 02:28:58 PM »
10k +
Ok, yes, if driven carefully, I’m guessing.
The link for the final drive. Is it a drum brake model? As I couldn’t see the acutuating arm orifice.
Re: Wear Shock!
« Reply #15 on: September 26, 2019, 03:00:35 PM »
10k +
It seems at least half of the width of the teeth has been eroded in 1000 miles. Getting more than another thousand miles out of that shaft would be good luck.
Offline Soggz
Re: Wear Shock!
« Reply #16 on: September 26, 2019, 03:43:39 PM »
Not looking good then...
Offline Soggz
Re: Wear Shock!
« Reply #17 on: September 26, 2019, 03:49:27 PM »
Ok. Conflicting answers, then. So, is it any good or not?
Re: Wear Shock!
« Reply #18 on: September 26, 2019, 03:53:53 PM »
look... i deal in reality... not grandiose delusions...
when i said to getts a lorry in que and not worry about it... i meant it...
if you gonna ride it like that you oughtta be prepared to make the walk of shame or call a flattbedd wrecker... its that simple...
Offline Soggz
Re: Wear Shock!
« Reply #19 on: September 26, 2019, 04:06:12 PM »
Ultimately then, I need another final drive and another set of splines!
Offline Soggz
Re: Wear Shock!
« Reply #20 on: September 26, 2019, 04:43:53 PM »
Or sell it to some other guy...
Offline Soggz
Re: Wear Shock!
« Reply #21 on: September 26, 2019, 05:02:44 PM »
when i said to getts a lorry in que and not worry bout it... what does that mean ffs?
Re: Wear Shock!
« Reply #22 on: September 26, 2019, 05:17:31 PM »
It means have a flatbed truck lined up to haul your moto off the roadway when the driveline fails, but in the meantime enjoy the ride until the inevitable failure occurs.
Offline Soggz
Re: Wear Shock!
« Reply #23 on: September 26, 2019, 05:20:52 PM »
Ah,ok.
I have trouble understanding Johnny, as I’m not sure if he is of this world.
Offline Soggz
Re: Wear Shock!
« Reply #24 on: September 26, 2019, 05:22:35 PM »
Ah,ok.
