Author Topic: Wear Shock!  (Read 37332 times)
Re: Wear Shock!
« Reply #25 on: September 26, 2019, 05:25:18 PM »
it is a self fullfilling prophecy.
the more wear on the splines, the more slop in the joint
the more slop in the joint the faster the wear on the splines.
every time you shift or roll on/off throttle causes loose splines to crash against each other.  it is not a linear failure curve, the more wear, the faster it goes south.
bricks with new shaft and fd splines are SOOOOO smooth.  it is incredible how much of a difference this makes in the ride.
Re: Wear Shock!
« Reply #26 on: September 26, 2019, 05:27:09 PM »
Ah,ok.
I have trouble understanding Johnny, as I’m not sure if he is of this world.
but he was speaking in the language of "old england"......
Offline Soggz
Re: Wear Shock!
« Reply #27 on: September 26, 2019, 06:04:05 PM »
talking bollox more like.
  • Down in Selwood Forest
Offline Soggz
Re: Wear Shock!
« Reply #28 on: September 26, 2019, 06:21:54 PM »
Offline volador
  • NEEDS MORE CHROME
Re: Wear Shock!
« Reply #29 on: September 26, 2019, 07:03:58 PM »
It seems at least half of the width of the teeth has been eroded in 1000 miles. Getting more than another thousand miles out of that shaft would be good luck.
Talking tosh  :dk bmp
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Re: Wear Shock!
« Reply #30 on: September 26, 2019, 07:13:10 PM »
Re: Wear Shock!
« Reply #31 on: September 26, 2019, 07:28:02 PM »
Just curious, is the replaced spline some sort of after market thing,  do you know what grade of cheese it is.
Re: Wear Shock!
« Reply #32 on: September 26, 2019, 07:34:07 PM »
. . . do you know what grade of cheese it is.
Re: Wear Shock!
« Reply #33 on: September 26, 2019, 07:51:21 PM »
Watching Monty python is one of the few occasions where I can be confident my memory is great.
Agree Agree x 2 View List
Offline Soggz
Re: Wear Shock!
« Reply #34 on: September 27, 2019, 12:57:41 AM »
cheddar
Offline Soggz
Re: Wear Shock!
« Reply #35 on: September 27, 2019, 02:58:35 AM »
Offline Soggz
Re: Wear Shock!
« Reply #36 on: October 03, 2019, 01:33:26 AM »
Joy! Found a newer FD with great splines of only 35,000 miles on them, also, a free set of splines are being sent to me. I may harden and temper them before welding, perhaps?
Re: Wear Shock!
« Reply #37 on: October 03, 2019, 08:14:30 AM »
I would think thar you need to harden them after welding.  Did you get any heat treating instructions with the spines?
Offline Soggz
Re: Wear Shock!
« Reply #38 on: October 03, 2019, 12:08:39 PM »
No instructions, as Motobins just get a batch of them, then sell them on.
Re: Wear Shock!
« Reply #39 on: October 03, 2019, 12:23:28 PM »
. . . Motobins just get a batch of them, then sell them on.
Apparently they also mate them to driveshafts, or contract with somebody else to do that.
Offline Soggz
Re: Wear Shock!
« Reply #40 on: October 03, 2019, 12:26:12 PM »
yeah, I know.
Re: Wear Shock!
« Reply #41 on: October 03, 2019, 12:28:55 PM »
yeah, I know.
I posted that information for the benefit of others who might not have gotten that impression from what you wrote. Anyway, it seems as though they would have information about the process.
Re: Wear Shock!
« Reply #42 on: October 03, 2019, 01:22:43 PM »
See if Motobins can tell you the steel grade.  With that information any competent welder can harden the splines.
Offline Soggz
Re: Wear Shock!
« Reply #43 on: October 03, 2019, 01:37:42 PM »
They don’t know.
Re: Wear Shock!
« Reply #44 on: October 03, 2019, 05:03:49 PM »
You need to check the hardness. Type in "How to check the hardness of steel". Do a few checks on the outside one near the weld one near the end and one on the teeth. Or go to your local friendly engineering shop with a bottle of suitable beverage and ask them to check it.
Offline Soggz
Re: Wear Shock!
« Reply #45 on: October 03, 2019, 05:11:18 PM »
Good idea.
Thanks Martin.
Offline Soggz
Re: Wear Shock!
« Reply #46 on: October 04, 2019, 02:37:12 AM »
Looked on the YouTube about checking hardness. The ‘ball bearing’ drop looks like a way for me to check, in my own garage.
Offline Soggz
Re: Wear Shock!
« Reply #47 on: October 07, 2019, 03:51:58 PM »
How do these look to you all?
Offline Soggz
Re: Wear Shock!
« Reply #48 on: October 08, 2019, 03:05:21 AM »
Anyone?
Re: Wear Shock!
« Reply #49 on: October 08, 2019, 03:20:29 AM »
Maybe make some better photos.
