Author Topic: Wear Shock!  (Read 37325 times)
Offline volador
  • NEEDS MORE CHROME
Re: Wear Shock!
« Reply #50 on: October 08, 2019, 11:52:33 AM »
They look brilliant! Get some Staburags and good riding. Use your home brew moly mix on the tractor. It's just lubing the sidewalls of the final drive cavity.
Staburags 10g
Staburags 20g
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline Soggz
Re: Wear Shock!
« Reply #51 on: October 08, 2019, 01:59:11 PM »
Maybe make some better photos.
yeah. Don’t get much better, unfortunatly.
  • Down in Selwood Forest
Offline Soggz
Re: Wear Shock!
« Reply #52 on: October 09, 2019, 09:12:28 AM »
it is a self fullfilling prophecy.
the more wear on the splines, the more slop in the joint
the more slop in the joint the faster the wear on the splines.
every time you shift or roll on/off throttle causes loose splines to crash against each other.  it is not a linear failure curve, the more wear, the faster it goes south.
bricks with new shaft and fd splines are SOOOOO smooth.  it is incredible how much of a difference this makes in the ride.
Yes.
Once I’ve mashed the old ones up good and proper in a thousand or so miles,I will have learnt my lesson.
This came today, from California. Shame they didn’t pack any sunshine in the box!
Interestingly, though, Im surprised the splines in the FD arnt longer, now that you can see it from the other end, with no drive shaft! Quite a gap for your grease to go missing up into!
Offline Soggz
Re: Wear Shock!
« Reply #53 on: October 14, 2019, 08:13:13 AM »
Staburags 10g
Staburags 20g
£13.00!, Really? Is there platinum in it?
Re: Wear Shock!
« Reply #54 on: October 14, 2019, 09:27:49 AM »
That's like ten years' supply.
Re: Wear Shock!
« Reply #55 on: October 14, 2019, 10:10:42 AM »
Organic spirulina perhaps. :-) A thorough application firmly applied with a loaded toothbrush on clean, smooth, dry splines should be enough. Excess will be flung off and wasted—as volador indicated previously. It's effective, durable lubricant so can be used elsewhere.
Offline Soggz
Re: Wear Shock!
« Reply #56 on: October 14, 2019, 12:16:14 PM »
Bloody expensive, though.
Offline xyxy
Re: Wear Shock!
« Reply #57 on: February 04, 2024, 03:01:59 PM »
I am trying the Chris Harris silicone plug method to help relieve lubrications creep.
Hey Soggz, if you still have your K bike, wondering how that silicone plug worked out?
  • North California
  • '88 K 75 S (0563,0572)
'21 R NineT Scrambler
