Well, I am totally thrilled with the vinegar outcome! Thank you Gryphon for the suggestion. I suppose the grime in the tank is a type of varnish left by the sitting gas and is not as hard to dissolve as it looks. I used (2) one gallon bottles of white vinegar and only let it sit 24 hours. I capped the fuel supply tube with left over rubber fuel hose so the vinegar wouldn't leak out. I cut the float arm and sensor device off the fuel gauge mounting plate and scewed the plate and old gasket back on to seal the bottom of the tank. Today, after the tank sitting for 24 hours in vinegar, I came home and made up a little scrubbing device from a 2' piece of 1/4" dowel with a piece of scotchbright pad attached to the end via one of the hose clamps. With the dowel I didn't have to worry about scratching the tank. I got into most of the nooks and crannys and was able to scub down the sides pretty well. Siphoned off the vinegar and rinsed the tank with the garden hose jet spray (that worked really well). Now the tank is drying out for a final vacuum tomorrow.
Here's the scrubbing device.
fullsizeoutput_37e6.jpeg (22.92 kB . 768x576 - viewed 2635 times)Here is a shot of the damping material on the tank bottom. It looks in good shape so I don't plan on replacing it.
IMG_0010.JPG (96.19 kB . 768x576 - viewed 2607 times)So it looks like the tank is almost ready to go. I would appreciate any input as to the sequence of list items to tackle before attempting to start the bike. Keep in mind the bike has been sitting for over 10 years with gas and all other fluids in it.
Here is a list of items that I know needs to be attended to but not sure what would be the correct order:
New battery
Check radiator, drain, flush, and new fluid
Check and possibly clean injectors
Replace spark plugs
Air filter
Change oil
Once I get the bike running I will plan on replacing brake fluid and lines, checking calipers and pads, make sure all electrics work, new tires, etc.
Thanks!
