Author Topic: Awakening 1987 K100RS from 10 year slumber.  (Read 183634 times)
Offline SpecialK
Re: Awakening 1987 K100RS from 10 year slumber.
« Reply #25 on: June 30, 2019, 05:04:59 PM »
Thanks guys for the spline info. Seems that's one of the most common issues to look after on these bikes. Will definitely check the slines when the time comes.
  • Wappingers Falls, New York
  • 1987 K100RS
"The first to present his case seems right, till another comes forward and questions him". Proverbs 18:17
« Reply #26 on: June 30, 2019, 08:37:44 PM »
I do mine as part of the end of season maintenance ritual.  I don't pay any attention to miles although I do record the odometer reading, and last year started taking photos of the splines to document their condition as part of the maintenance record.  My bikes annually get about 4-5,000 miles on the RS, and about 7-8,000 on the RT.
The RT now has a bit over 92,000 milles and the splines are just beginning to show a hint of wear.  I would expect them to get me to at least 150,000 miles before I'll need a new driveshaft or final drive.
Offline SpecialK
« Reply #27 on: July 01, 2019, 08:29:36 AM »
They look to be in decent condition. Am curious to see what mine look like when I get in there. Have no idea if the bike was driven hard on rough roads or pampered. I'm hoping for the latter :2thumbup:
  • 1987 K100RS
Offline natalena
« Reply #28 on: July 01, 2019, 09:21:05 AM »
The fun thing about checking splines, is it's like opening a Kinder Egg. Sometimes it's a so-so toy, and sometimes it's awesome and worth dancing around the brick like a savage.
  • MST
Offline SpecialK
« Reply #29 on: July 01, 2019, 08:23:59 PM »
Not much work today except took the temperature sensor out of the water pump and drained the rest of the fluid. I saw a guy on youtube pull the wire clip off and use a 14mm socket so that's what I did. See photo.
* IMG_0002.JPG (46.67 kB . 768x576 - viewed 1383 times)
Here is another photo of a rubber, looks like crancase vent tube, in front of the air filter housing, that has a hex scew in it. Is the tube supposed to be open? Why would the hex screw be in there?
Thanks.
* IMG_0003.JPG (52.5 kB . 768x576 - viewed 1367 times)
  • 1987 K100RS
Offline natalena
« Reply #30 on: July 01, 2019, 08:34:13 PM »
That hex looks like it's plugging the tank vent tube that leads to the crankcase. Nearly everyone has that tube crimped, plugged or removed and the case hole plugged. No worries. The origin of the tube is the two nipples on the bottom of the gas tank.
  • MST
Offline SpecialK
« Reply #31 on: July 01, 2019, 08:40:26 PM »
Yes I saw those nipples. don't they just rest inside that little plastic cup under the tank?
  • 1987 K100RS
« Reply #32 on: July 01, 2019, 09:55:48 PM »
When you put the temperature sender back into the water pump be careful to only get it a bit more than snug.  The sender has a thin wall at the top of the threads, and if you get carried away with torque it will break off.
« Reply #33 on: July 01, 2019, 11:09:34 PM »
Once upon a time, that vent tube was also attached to one of the two ports that now empty into the cup attached to the frame. There was a one-way valve in the middle of it. The tube's purpose was to meet California emission standards by venting fumes from the tank into the crankcase. It was an imperfect idea so the remedy was to remove the hose from the fuel tank then either plug the crankcase port or plug the hose, as natalena indicated. Somebody screwed your hose to plug it.  If the crankcase port were not plugged, the engine would likely run rough or stall.
After decoupling that from the crankcase, the tank vent port—and the fuel cap water drain port next to it—either had hoses attached to them that dumped behind the right foot peg plate, or the ports dumped into a cup attached to the frame like yours do. The cup should have a hose attached to the underside of it that dumps downward behind the right foot peg plate.
  • 1995 K75 89,000 miles
Offline SpecialK
« Reply #34 on: July 01, 2019, 11:14:02 PM »
Thanks. Yes I saw that in the Haines manual torque to 9.
  • 1987 K100RS
Offline SpecialK
« Reply #35 on: July 02, 2019, 06:05:17 PM »
Received fuel parts and battery from EME today. Not bad, ordered Friday and received today Tuesday, from Colorado to New York, Fedex. Anyway, here are the pics of the goodies.
Enduralast 52mm fuel pump kit (pump, housing, anti-vibration, fuel lines, fuel filter, filter cup, screws and clamps).
* fullsizeoutput_37f6.jpeg (63.44 kB . 768x524 - viewed 1288 times)
WestCo 12V30 AGM battery.
* IMG_0002.JPG (43.88 kB . 768x576 - viewed 1372 times)
BMW OEM fuel level sensor.
* fullsizeoutput_37f4.jpeg (36.62 kB . 768x347 - viewed 1290 times)
Will work on getting these installed over 4th Holiday. I am curious to see how the electrics come on after hooking up the battery.
Question; What is the best way to try an initial start-up since there may be old fuel in the lines and injectors? Should I take the injector rail out and crank the starter to expel old fuel out the injectors and into a container, or leave everything as is and try to start?
I will have to also refill the radiator with antifreeze since I drained it. I am figuring I can change the oil and filter after I get it started.
Thanks.
  • 1987 K100RS
Offline SpecialK
« Reply #36 on: July 02, 2019, 06:33:54 PM »
Regarding antifreeze coolant, radiator flush, oil and filter;
Are there common brands suitable for the K bikes available at the auto parts stores? I heard some people say they use any old antifreeze 50/50 like Prestone but I thought it should be specifically for alluminum block engines?
Thanks.
  • 1987 K100RS
« Reply #37 on: July 02, 2019, 08:46:45 PM »
I heard some people say . . .
I knew a guy who smoked two packs of cigarettes a day and lived to be 80. I quit smoking anyway. :giggles
Any extended life (long-life) coolant without nitrites is acceptable to BMW, according to the coolant specs within its rider's handbook for the K75, so read the label.
Offline natalena
« Reply #38 on: July 02, 2019, 10:42:00 PM »
I only use BMW branded oil filters due to superstitious beliefs that the engineers knew what they were doing, as well as, the finance department at extracting your funds.
Since there's jugs of Mobil 1 Synth. in the garage, that's what I use. No gasket leaks, seal issues, or capricious running noted so far, as opposed to dino-oil.
  • MST
« Reply #39 on: July 03, 2019, 09:37:47 AM »
I get my oil filters from Carquest/Advanced who has WIX make them.  They are rated highly in tests of filter performance.  The part number is 85348.
After reading a number of technical articles on oil, I have decided to get the oil with the highest possible film strength in psi.  The best readily available is Quaker State Ultimate Durability Full Synthetic 5w-30 which has a film strength better than 85% of the oils for sale today.   The best part is that Walmart sells it for $17.77 for a 5 quart jug.
For coolant, I am using Peak Long Life mixed 60/40 with distilled water.  It is stated to be safe for all engines and won't void new car warranties.  Nearly every new engine today has an aluminum block, and antifreeze manufacturers have had to adjust their formulas to accommodate the new engine requirements.
Offline SpecialK
« Reply #40 on: July 03, 2019, 10:44:17 AM »
That is really good information Gryphon! I was looking at the coolant in Advanced last night. Prestone has Long Life Dex Cool for aluminum radiators in full strength for $18.99 so that may be good as like you say, most of the formulas are designed for newer aluminum block engines.
Have you ever used a flush product for the radiator? I want to do that before I add any new coolant.
  • 1987 K100RS
Offline natalena
« Reply #41 on: July 03, 2019, 11:03:40 AM »
Prestone antifreeze works well, and I religiously use distilled water after a bad episode with a 320i radiator.
Flushing with white vinegar works well. A gallon is cheap, when mixed with water and run to warm the motor, leave it overnight, drain, flush out with the hose, and fill with whatever antifreeze/strength you like.
Sounds like you're having fun with the process, and bonding with your brick. :)
  • MST
« Reply #42 on: July 03, 2019, 11:13:27 AM »
Natalena is right about the white vinegar.  If it isn't too much hassle right now, it might be a good time to pull the radiator and clean the accumulation of dirt and dead bugs that is in the fins, blocking the airflow.
I did it with my first K100 and it really cooled off the engine on hot days.  It's something I'm going to have to do on the one I have now as the temperature gauge is reading a lot higher on hot days lately.
Offline SpecialK
« Reply #43 on: July 03, 2019, 01:10:30 PM »
I am so glad you guys said the vinegar is good. I was thinking that since it worked so well cleaning the aluminum gas tank, why not the radiator. Now I don't have to go hunting down another $$ product.....and yes I am having fun, so far, as long as the process keeps going smoothly.... :yikes:
  • 1987 K100RS
Offline SpecialK
« Reply #44 on: July 03, 2019, 01:14:04 PM »
Good idea, thanks for that advice. Doesn't seem too difficult and would benefit in the long run.
  • 1987 K100RS
Offline SpecialK
« Reply #45 on: July 04, 2019, 04:46:42 PM »
Today I took the plugs out to check. They look oily, like the engine was running rich or maybe just from sitting or the PO shot some oil in the holes before storage?
I checked the gap and I couldn't get the plug to slide over the slimest point on the gap tool, .5mm. Specs say they should be 0.6 - 0.7mm. Is this narrow gap OK or open them to 0.6 - 0.7?
I tried turning the rear wheel (by hand) with bike on the center stand in first gear but could not (with the plugs out so no compression). The pistons move though once I roll it and let the clutch out. Is it usually too hard to turn by hand?
Also, in the relay box under the tank, there is a white and a black pin connector that are not connected to anything (see photo). Where do these go? Accessories?
Here are some photos:
Plugs and cylinder head
* IMG_0001.JPG (57.57 kB . 768x576 - viewed 1225 times)
* IMG_0002.JPG (55.56 kB . 768x576 - viewed 1266 times)
Open pin connectors
* IMG_0003.JPG (45.76 kB . 768x576 - viewed 1355 times)
  • 1987 K100RS
« Reply #46 on: July 04, 2019, 06:09:52 PM »
Always go with the specs unless you're operating with cosmic dispensation for negligence. A gap that's too narrow will not fire hot enough. New plugs should be checked for correct gaps.
Offline SpecialK
« Reply #47 on: July 04, 2019, 06:24:39 PM »
Maybe that explains the oily appearance? They weren't firing hot enough. I will use the gap tool to spread them to 0.7mm.
Any idea about the blank plugs in the relay box?
Thanks Laitch.
  • 1987 K100RS
« Reply #48 on: July 04, 2019, 06:36:28 PM »
Which rotation direction were you tuning it, why didn't you try turning the wheel while the transmission was in a higher gear, and what was your objective? Debris from the cylinder head could have gotten sucked into the cylinder bores if you weren't a Tidy Timmy before your experiment.
They don't go anywhere. They're happy where they are. The largeer is an accessory plug that has both switched and unswitched power; the smaller can also be use for appropriate accessories or an alarm.
Offline SpecialK
« Reply #49 on: July 04, 2019, 06:44:04 PM »
I was turning forward. I didn't think to move to a higher gear, thought first would be easiest The objective was to make sure pistons were not froze up.
  • 1987 K100RS
Tags: speedometer
