Author Topic: Wiring LED turn signal lights  (Read 6226 times)
Offline Emjk431
« on: June 05, 2017, 08:49:59 PM »
As I can't find a replacement RS turn signal lens I'm thinking about wiring in some LED turn signals in there place. I've looked through some post but couldn't find the information I was looking for.  Do I need a resistor? Or can I wire them direct to the old wiring ?  Any help or ideas would be great.  I'd like to keep the RS mirrors as I like the look.
Thx
  • Sudbury Ontario Canada
  • 87 k100, 99 zx7r, 02 zx6r, 82 kz650, 01 CR 250r
Re: Wiring LED turn signal lights
« Reply #1 on: June 05, 2017, 11:13:53 PM »
Thx
This is the thread that discusses your interest. You should read all of it first before you do anything.
http://www.motobrick.com/index.php/topic,659.msg1966.html#msg1966
This is post #3 of the thread that suggests a simple way to get LED signals to work.
http://www.motobrick.com/index.php/topic,659.msg28670.html#msg28670
This is the post—#20—in the thread that shows you exactly what you'll need to do eventually that was discussed in post #3 of the thread.
http://www.motobrick.com/index.php/topic,659.msg46416.html#msg46416
Yr wlcm
« Reply #2 on: June 06, 2017, 01:02:33 AM »
If you have the turn signal relay with the through hole components instead of the SMD components, the cut this trace:
« Reply #3 on: June 06, 2017, 07:09:25 AM »
Now this thread is the thread and you're part of it, Emjk431!  :clap:
Offline Emjk431
« Reply #4 on: June 06, 2017, 09:55:51 AM »
Thanks information  guys.  I'll read the threads
