Author Topic: Spiegler Brake lines  (Read 2548 times)
Offline jaxon
« on: June 02, 2017, 02:24:27 PM »
The Spiegler brake line kit (ABS version) I got went well enough for the rear set. The front set include the right part from the master cylinder to the junction under the tank. The other part had a F10 connector with a banjo.
No worky, nothing on that part of my bike plays banjo. Spiegler was kind enough to send me a 390mm line with 2 F10 connectors which is the standard internally threaded connection. Seems the junction under the forks requires an F11, which has a groove to fit within the mount.
Wonder if I should risk it. I mean it's not a perfect match and there is no groove on the F10. It would likely be unanchored in the mount.
Anyway, Thanks to Spiegler for sending another line albeit not a perfect match.
  • Indiana
  • '92 K75S, '17 R1200GS LC
This space for rent
