Author Topic: Swing Arm  (Read 5350 times)
Offline Roland
Swing Arm
« on: May 28, 2017, 09:02:19 PM »
Is there a heat treat on the swing arm? What alloy is it? i want to weld something to it and wanted to know if that would get rid of any heat treat that was on it. Thank you
  • California
  • 1985 k100rt
Re: Swing Arm
« Reply #1 on: May 28, 2017, 09:41:48 PM »
If you give us a picture of where and what you want to weld on to it, it would be helpful.  :dunno
Regards Martin
Offline Roland
Re: Swing Arm
« Reply #2 on: May 28, 2017, 10:52:03 PM »
I want to weld an aluminum flange to hold a suspension piece onto the pint where the socket is. Any ideas on how to move the shock to where the battery is would be muchly apreciated as well.
  • California
  • 1985 k100rt
Re: Swing Arm
« Reply #3 on: May 28, 2017, 11:21:31 PM »
If you intend for it to support a mount for a shock absorber it would definitely break. Take a look at where the OEM shock is mounted and compare. There is no comparison.  :nono  Maybe if you explain fully what you are tying to do and why, one of the inmates may come up with something. If moving the shock into a horizontal position is your intention it can and has been done but at great expense, and a lot of math and engineering is involved.
Offline Roland
Re: Swing Arm
« Reply #4 on: May 29, 2017, 01:41:47 AM »
I eant to put a flange and a rocker at that point and have a shock and rod go to to where the joint is in the frame. I will put a stiffer spring and shock to compensate for the loss of leverage. I just wanted to know if the awing arm was hardened or not.
  • California
  • 1985 k100rt
Re: Swing Arm
« Reply #5 on: May 29, 2017, 05:34:05 AM »
There was a post on a K100 with custom rear suspension. If I find it I'll post it.
Regards Martin
Re: Swing Arm
« Reply #6 on: May 29, 2017, 05:39:55 AM »
Image result for BMW k100 custom rear horizontal shock suspension
Re: Swing Arm
« Reply #7 on: May 29, 2017, 05:44:40 AM »
