Author Topic: Water / Oil pump service kit or replace  (Read 5789 times)
Offline Pdm23
« on: May 22, 2017, 02:00:36 PM »
There is oil leaking  around the front of engine, looking like pump. Although there's also oil around the right hand edge of sump where engine protector bar attaches.
I'm hoping it's all coming from the pump and being spread around when bikes on road.
Wondering about the procedure to remove the pump and either replace all the seals and gasket or swap for another one.
  • Barnsley
Re: Water / Oil pump service kit or replace
« Reply #1 on: May 22, 2017, 02:02:43 PM »
post up some photos of those oil leaks...
« Reply #2 on: May 22, 2017, 02:10:48 PM »
Once you've posted photos of the leaks. If you can't determine where the leaks are, clean the area thoroughly with your favourite degreaser cleaner and let it dry. Then spray the suspect area with spray on talc in your favourite fragrance, go for a ride. The talc will help show up the source of the leak.
Offline Pdm23
« Reply #3 on: May 22, 2017, 02:41:49 PM »
There's a fair bit of oil at the back of the oil pump front cover.
  • Barnsley
« Reply #4 on: May 22, 2017, 03:05:58 PM »
:useless
Offline Pdm23
« Reply #5 on: May 22, 2017, 03:17:23 PM »
I'll get some tomorrow and post.
  • Barnsley
Offline Pdm23
« Reply #6 on: May 22, 2017, 03:21:39 PM »
Oil leak pics later
  • Barnsley
« Reply #7 on: May 22, 2017, 03:26:23 PM »
It can't be leaking too badly. There isn't an oil spot on the pavement beneath it.  :2thumbup:   Thanks for the pics.
Offline Pdm23
« Reply #8 on: May 22, 2017, 03:28:27 PM »
it's more splashed up around back of  pump hosing.
  • Barnsley
« Reply #9 on: May 22, 2017, 03:31:27 PM »
Out of sight, out of mind. :giggles Clean it all off then do what Martin suggested and take photos of the fresh tracks.
Offline F14CRAZY
« Reply #10 on: May 23, 2017, 06:33:14 PM »
I gave up trying to replace the seal in mine and just swapped a used one from a K1200LT
  • Grand Rapids, MI
  • '87 K75C
