Author Topic: final drive shaft inspection  (Read 7204 times)
Offline vytasas
« on: May 11, 2017, 02:10:05 PM »
Hi fellas,
Some wear and tear after 70,000 miles, but look okay to me?
  • Vilnius, Lithuania
  • K75 '94 ABS
Re: final drive shaft inspection
« Reply #1 on: May 11, 2017, 02:36:25 PM »
The driveshaft spline you show is starting to get sawtoothed but still has several thousand miles left on it.
The photo of the rear drive spline does not show condition well enough. Take another photo directly in front of it and just slightly above it with good lighting. Right now it looks excessively worn but that appearance might be an effect of the photo's angle.
« Reply #2 on: May 11, 2017, 06:58:39 PM »
That driveshaft is trashed.  FD is in same condition.
Offline jakgieger
  • itinerant farmer
« Reply #3 on: May 11, 2017, 08:47:03 PM »
A little harsh :bmwsmile , but most likely the case.  The miles did not do this..lack of grease did.  Option 1, drive it until it shells out (Laitch most likely is right).  Option 2, spend a lot of money (there are other splines on the bike, when the rear looks that bad, the others are worn most likely).  Option 3, create a donor bike...Good luck
  • Kansas USA
  • 1989 K100rs se
Offline BrickMW
« Reply #4 on: May 11, 2017, 09:04:02 PM »
Should be more like this.
Sent from my SM-G935V using Tapatalk
  • Huntsville, AL
  • 1986 K75c
Offline vytasas
« Reply #5 on: May 11, 2017, 11:26:37 PM »
i will post photos today after thoriugh cleaning, the final drive might not be so trashed after all :)
  • K75 '94 ABS
Offline TX brick
« Reply #6 on: May 12, 2017, 06:10:59 AM »
The driveshaft on my 91 was a little worse than that at 30,000 miles. I started lubing it at every tire change and got another 30,000 miles before it was worn to the point of near failure.
Ron
91 K75RT
Belton Tx
« Reply #7 on: May 12, 2017, 09:04:13 AM »
Now that right there is confidence! :2thumbup:
Offline TX brick
« Reply #8 on: May 12, 2017, 09:25:42 AM »
I wasn't all that confident. I carried a spare driveshaft on trips.
Ron
91 K75RT
Belton Tx
Offline vytasas
« Reply #9 on: May 12, 2017, 09:28:21 AM »
at least now i have an estimate  :deal:
  • K75 '94 ABS
« Reply #10 on: May 12, 2017, 12:25:44 PM »
The spare would allow for even more confidence. Let's not look behind the curtain, Tx.
Offline vytasas
« Reply #11 on: May 12, 2017, 03:04:31 PM »
doesnt look so bad after all
  • K75 '94 ABS
Offline Elipten
« Reply #12 on: May 12, 2017, 04:42:24 PM »
Looks okay from that angle
Sent from my iPhone using Tapatalk Pro
  • San Antonio, TX
  • 1990 K75RT
« Reply #13 on: May 12, 2017, 06:30:28 PM »
From what I see there, I wouldn't be worried if that were on my bike. Invest in a new driveshaft when you have enough euros.
