Author Topic: Side to side play in final drive / pivot adjustment question  (Read 2508 times)
Offline CrashBar
« on: April 15, 2017, 04:34:01 PM »
1993 K1100LT 143,000 miles.  In the middle of re-assembling my final drive after a spline lube. Right now it is dry (no gear oil inside).  If I hold either side of the disc break I can rock it back and forth a little.  I put a dial indicator on the outer edge of the disc, it's about .030 of play.
Normal?   Normal wear?  Or a potential trouble spot?  Otherwise it is fine.  I'm getting ready for a big trip this summer (Trans Labrador Highway) so everything is getting the once over, and I'm a little more paranoid than usual.
Also, standard procedure is to tighten the left side (inboard) bolt (the big one) all the way flush, and then tighten the outboard side until snug and use the locking nut to hold in place? This is what I usually do, but the rubber boot is *awfullly* close to the disc.  Seems like the whole thing should be shifted over a smidge....
  • Boston MA
  • 1993 K1100 LT
....to trade in these wings on some wheels...
1993 K1100 LT (143,000 miles and counting)
1973 CB350F / 1978 CB550K / 1973 TR5T
Offline BrickKollector
Re: Side to side play in final drive / pivot adjustment question
« Reply #1 on: April 20, 2017, 05:12:03 AM »
There should be absolutely NO play. You need to establish whether it is the crown FD wheel bearing or the pivot pins that are the cause of the movement. I would start with the pivot pins as these are straight forward to set with a torque wrench. Just 'nipping them up' is not good enough so invest in a small 1/4 inch quality torque wrench. If the play still remains it is likely the crown wheel bearing in the FD. To check this ask a friend to rotate the wheel while you hold a large screw driver with the pointy bit on the other edge of the FD and the handle against your ear. If the bearing is worn you will hear quite a rumbling sound through the handle of the screw driver.
  • Wanaka, New Zealand
  • 1987 K100RS, 1991 K1, 2002 K1200RS
Current rides:
2002 K1200RS Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 164,000km
1991 K1 Blue, under restoration. 74,000km
1987 K100RS Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 52,000 miles.
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grand dads ride
