Author Topic: blinker cancel flakey  (Read 4829 times)
Offline Rcgreaves
« on: March 19, 2017, 09:33:20 PM »
So I bought a used right handle bar switch assembly for the starter switch and the blinker cancel mechanizm only activates with a sort of twisting side press to the button... is this serviceable?  I have another unit..
 No I haven't sprayed the contacts yet but tomorrow I plan to.
thanks for any advice.
Doing “better than I deserve"
Re: blinker cancel flakey
« Reply #1 on: March 19, 2017, 10:20:30 PM »
Shoot some DeOxit into that puppy.  The stuff is magic.
Offline Rcgreaves
  • 1995 K75 89,000 miles
Offline Elipten
« Reply #4 on: March 20, 2017, 10:46:10 PM »
Magic juice for k bikes.
  • San Antonio, TX
  • 1990 K75RT
Offline youngbill
« Reply #5 on: April 09, 2017, 01:06:49 AM »
I stripped the right hand assembly down and cleaned the contacts,if you do the same there are little springs and a ball bearing so do it on a clean bench and keep your eyes peeled fo said "bits".All went well,cancel and lights all working well,not too difficult really.
Sent from my HTC One A9 using Tapatalk
Offline Rcgreaves
« Reply #6 on: April 09, 2017, 07:21:08 AM »
youngbil.  Check and check on springs and ball bearings.  Not yet serviced but having the papa thrill of helping my son restore his ride.  cheers. :riding:   Should be an epic day for riding in Cheeseland, the empire of cheese, the ruler of the cheese roost, Wisconsin.  Better swig some more coffee.
Offline Rcgreaves
« Reply #7 on: April 11, 2017, 08:16:34 PM »
So yesterday my Brick hit the road for the first time in 6 months after a string of challenging maintenance issues.   :clap: As for the flakey blinker cancel:
 I opted to try my in stock electrical contact cleaner before a Deoxit purchase.. with  one of those handy dandy red straws nozzles.
Firstly we wrapped the headstock with a moving blanket to catch any over spray especially the gauges.  Then we opened the switch assembly.  Without opening up the switches ( and the resulting "sproingy" sound of tiny springs seeking a crack in the floor) I worked each control and sprayed into the openings at all sorts of angles. Reassembled, prettied up the plastic with that Back to Black plastic cleaner that seems to bring color back to any colored plastic, and tested.  Worked perfectly.
Clearly oxidization was the culprit here. Thanks all.
« Reply #8 on: April 11, 2017, 08:39:50 PM »
Worked perfectly.
Thanks for the followup!  :clap:
Offline Rcgreaves
« Reply #9 on: April 11, 2017, 09:30:06 PM »
Thanks for your interest and support!
Sent from my A573VC using Tapatalk
