Author Topic: Is there any chain adjustment on the K11?  (Read 5567 times)
Offline zalle
« on: March 08, 2017, 04:22:29 AM »
Hi, I used to adjusting the primary timing chain on my other bike, loosen a bolt, tighten a screw, tighten the bolt...
Is there any of this in the K11?
Thanks
  • Portugal
  • K1100LT & Honda CBX1000
Re: Is there any chain adjustment on the K11?
« Reply #1 on: March 08, 2017, 07:47:07 AM »
The timing chain has a oil pressure automatic adjusting mechanism.
If the adjuster is out to it's limits, you will need a new chain.
How many miles on it?
1995 K1100LT 0302044 (R.I.P)
Offline zalle
« Reply #2 on: March 08, 2017, 08:01:34 AM »
Thanks Scott, it's all fine with the bike, just wanted to know.
She's still a baby, 40k  :riding:
  • Portugal
« Reply #3 on: March 08, 2017, 08:07:08 AM »
Be easy on it.  It's not broken in yet.
« Reply #4 on: March 08, 2017, 06:34:55 PM »
It's still not a bad idea to check the chain and adjuster occasionally.(say @ 50K miles or so)
The oil used to pressurize the adjusting mechanism also lubricates the nylon chain guide, and from time to time the 'lubrication passageway' will plug up and not lubricate the guide properly and cause pre-mature wear of the guide and thus the adjusting mechanism will limit out faster.
Offline Brick_hack
« Reply #5 on: April 26, 2017, 03:46:34 PM »
How do you check it? Or could you point me to where a description of it is?
  • Bellefontaine, OH
  • 1997 K1100LT
« Reply #6 on: April 29, 2017, 07:05:25 PM »
The only way to check it is to open the timing chain cover and look at it. There is no gasket other than rtv to seal it back up when installing the cover back on.
Offline Brick_hack
« Reply #7 on: May 01, 2017, 11:42:00 AM »
Thank you!
  • Bellefontaine, OH
  • 1997 K1100LT
