Author Topic: Oily Incontinence  (Read 8008 times)
Offline johnnyalpha
Oily Incontinence
« on: March 04, 2017, 01:13:58 PM »
OK a K75S, a 1987, at least 98K miles (when the odo stopped working yrs ago)  I noticed a drip of oil from the water/oil pump tell tale drain.
I went for a reconditioned pump from Motorworks in Yorkshire.
Installation without a problem,yesterday. Left 24hrs to let sealant do it's thing.
Today, put fluids back into bike , it fired up...............to my horror oil was simply pissing out of the tell tale drain,not a drip a stream.
NOT when bike running of oddly only when I switched off
Not well pleased,however let it run to see if it would need to bed in/settle in.
And lo, after a wee while it did,after losing about 100mls or so of oil.
Stopped bike and topped up to the dot,bloody thing started to piss oil again, bike NOT running.
Start the bike, the leak stops,stop the bike it starts to leak UNTIL the level disappears from the sight glass window,then it stops.
200 pounds for a reconned pump and it leaks :(
BUT I am intrigued that it leaks only when engine stops and only until level drops to below the sight glass.
Now , have Motorworks  neglected install the oil seal, or is it badly installed ?
OR, could it be the o ring on the smaller toothed gear wheel ???
OR something else, any help very much appreciated, Johnny Scotland
PS this is not the same bike that had the water in the tank problem recently
Re: Oily Incontinence
« Reply #1 on: March 04, 2017, 01:38:14 PM »
There's not much to correctly bolting up a rebuilt pump. You should take this up with Motorworks next time they are open. You might have gotten a dud with a poorly installed shaft seal; that's entirely likely.
Offline johnnyalpha
« Reply #2 on: March 04, 2017, 01:59:26 PM »
Hi Thanks for the reply. Aye i will come Monday morning.
The odd thing is that no oil leaks when engine is running,only when stopped.
AND that the leak, flow is a better description TBH, stops when the level in the sump/sight glass drops to a level approx = to 100-150mls of oil.
I tried NOT to block the return channel to the sump (wee half moon channel), but I may have,but can't predict how this would make itself known by a leak out the tell tale,mmhhhh
Also would a back to front oil seal on the shaft not leak ALL the time, even when engine running ???  I dunno :)
ho hum !!!   Johnny
« Reply #3 on: March 04, 2017, 02:31:13 PM »
ho hum !!!
That's the approach, right there. Think about something else. I'm fairly certain this will all get sorted with Motorworks.
Offline bocutter Ed
« Reply #4 on: March 04, 2017, 02:40:56 PM »
I would guess there is suckage when running, and blowage when stopped ...
  • Toronto, Canada
« Reply #5 on: March 04, 2017, 02:54:02 PM »
Suckage, for sure!
Offline johnnyalpha
« Reply #6 on: March 04, 2017, 02:58:20 PM »
I don't think I want to give an opinion on which is better, sucking or blowing   :hehehe
« Reply #7 on: March 04, 2017, 03:45:02 PM »
I don't think I want to give an opinion . . .
No offense will be taken, probably.
« Reply #8 on: March 04, 2017, 04:04:12 PM »
ill give an opinion...
queefing...
Offline johnnyalpha
« Reply #9 on: March 04, 2017, 04:22:59 PM »
My word !!!!  I had to Google that !!!! :mbird
« Reply #10 on: March 04, 2017, 04:46:50 PM »
bet you wish you hadn't!  :yow
Offline Bill
« Reply #11 on: March 04, 2017, 05:03:55 PM »
Wish I hadn't  :mbird
  • Sutton, Ontario, Canada
  • K100 LT
Current:  88 K100 LT
86 K100 R-?L?T parts collection in loose formation...
previous:
84 V45 Sabre
74 CB400
72 CB750
« Reply #12 on: March 04, 2017, 05:24:54 PM »
I have a machine that can analyze that for you.....
Offline bmwpyro
« Reply #13 on: March 04, 2017, 08:33:50 PM »
This is a fascinating topic! and a I learned a new word ! :eek:
  • Azusa, CA
  • 1985 K100RS, 1990 K75S
Always Learning...
Always something new to learn about riding and Kbikes...
"Viam inveniam aut faciam"
Offline bocutter Ed
« Reply #14 on: March 04, 2017, 08:52:57 PM »
OK, I have a bunch of milk crates hanging off the roof above the mezzanine. They are full of: spare parts & dead parts; metalworking good scraps; leather good scraps; computer cables; assorted junk; etc. And then there's one, second from the end, full of hoses, clamps, and misc fitting for the Gast vaccuum pump and the 7.5hp IR compressor ... labeled Suck & Blow.
  • Toronto, Canada
« Reply #15 on: March 04, 2017, 08:57:25 PM »
But does it have autosukcontrol?
Offline bocutter Ed
« Reply #16 on: March 04, 2017, 09:17:15 PM »
Kruise Kontrol?
  • Toronto, Canada
Offline johnnyalpha
« Reply #17 on: March 11, 2017, 04:11:26 PM »
Righto, got replacement from Motorworks,very swiftly sent.
Fitted today, and it is perfectly continent, no drips, drops or queefs !!!
Happy bunny now :)
 Johnny AKA  W D MacForte :)
