Author Topic: Fill engine cavities  (Read 5991 times)
Offline Boxermann
« on: November 21, 2016, 07:02:58 AM »
I'm removing the box that housed the AFM, and by that exposing the upper part of the engine. To make it easier to keep clean I'm thinking of filling the cavities marked in red with something. Steel epoxy?
Or would this be a bad idea because of heat?
  • K100 / '87, K75 / '87
Re: Fill engine cavities
« Reply #1 on: November 21, 2016, 08:23:45 AM »
Leave it alone and eat your dinner on a proper surface.
« Reply #2 on: November 21, 2016, 08:53:57 AM »
I cleaned out mine yesterday - years and years of accumulated crud was in there - I am pretty sure that can't help the cooling so I agree - leave them alone.
Offline kris
« Reply #3 on: November 21, 2016, 09:07:41 AM »
If you're worried about it why not consider some type of durable screening. That will keep small stones (and up) from collecting in there. Wouldn't be in a hurry to fill it. Even full of crud I can't imagine any real ill effects....
"I got bike fever bad!!"
« Reply #4 on: November 21, 2016, 10:10:24 AM »
I doubt it has anything to do with cooling, probably the cavities are there to save weight.  I sorta like the idea of filling them in.  Epoxy would certainly work, though it would be a pain if you changed your mine. Bondo is the only other thing I can think of offhand and seems like that would crack over time.
« Reply #5 on: November 21, 2016, 10:15:52 AM »
If you really want to fill them in, I would suggest using one of those foam caulks like Great Stuff.  Shoot it in, shape it, and then seal the surface by brushing on some polyester resin.  I wouldn't use epoxy because it tends to soften at high temperatures.
Offline Boxermann
« Reply #6 on: November 22, 2016, 05:18:55 AM »
Thanks for the input guys!
I think I'm going to your suggestion Mighty Gryphon. Cheap and easy to apply and no problem to remove if needed.
:2thumbup:
Offline BAMBAM1039
« Reply #7 on: November 22, 2016, 04:19:47 PM »
FOAM chalks are highly flammable  caution with use   good luck  also bondo will not take the heat as far as i know
  • CONNECTICUT
  • PRESENT 1990 KAWASAKI ZX11 TURBO 2010 VICTORY HAMMER S 1995 K1100LT PAST RUPP BLACK WIDOW BENELLI VOLCANO 180 1975 HONDA XL250 1977 HONDA MR175 1971 HONDA SL350 1974 INDIAN 100 1976 SUZUKI TS100 1984 KAWASAKI GPZ 750 1985 KAWASAKI NINJA 900 1984 KAWASAKI NINJA900/1000 NITROUS DRAG BIKE 1990 ZX11 1992 ZX11 1986 NINJA 1000 1990 ZX750 1998 zx9 2000 ZX12 2006 ZX10 2006 ZX14
Offline kris
« Reply #8 on: November 22, 2016, 04:32:41 PM »
Cement??.............. :dunno
(just kidding)
Offline Nine80seven
« Reply #9 on: November 22, 2016, 09:09:27 PM »
Every 80K miles take stuff off top of engine, squirt some cleaner, brush, use rags, squirt some more cleaner, wipe clean possible, put back together, go to go another 80K.
  • MN
  • 85 K100RS
