Author Topic: What's a Proper Kickstand Lean Angle for the K100?  (Read 4918 times)
Offline k
« on: November 04, 2016, 12:23:48 AM »
Mine feels like it drops way over. Is this normal? I had an RT previously, and I don't recall that one leaning quite as far.
:mm
  • Indiana
Offline TX brick
Re: What's a Proper Kickstand Lean Angle for the K100?
« Reply #1 on: November 04, 2016, 04:48:52 PM »
My 91 75RT leaned WAY over also and when replacing the pivot bushing didn't help much, I made a pad for the foot.  I used a one inch thick piece of plastic cut to shape and drilled two holes to bolt it on.
Ron
91 K75RT
Belton Tx
« Reply #2 on: November 04, 2016, 06:10:03 PM »
they all do that.   check for loose pivot and or bent side stand.
Offline Inge K.
« Reply #3 on: November 04, 2016, 08:45:10 PM »
or bent side stand.
Would like to add that they're slightly bent allready from factory.
  • Norway
Offline The Dude
« Reply #4 on: November 04, 2016, 09:43:12 PM »
Standard tire profile and suspension?
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline k
« Reply #5 on: November 04, 2016, 09:45:01 PM »
Yep. No deviations.
  • Indiana
« Reply #6 on: November 05, 2016, 09:43:51 AM »
I suspect that the radical lean these bikes have when they're on the side stand is intentional to lower the seat height so as to allow mere mortals to be able to swing a leg over it.
