Author Topic: K1100 LT Rear Brake Master Cylinder - Recommendations  (Read 3338 times)
Offline BK575
« on: October 19, 2016, 04:21:32 AM »
I recently purchased a K1100 LT in fairly nice condition. The previous owners have done a good job keeping her up to date with services and needed attention. However she does have a leaky rear brake master cylinder and has been leaking for some time. I recently took the master cylinder apart and cleaned it up a bit removing all the old and dried brake fluid and attempted to revitalize the rubber seals in hot water (old school trick). It cleaned up nicely. However, it still leaks, clearly the rubber seals need to be replaced.
So here is my question, should I just pony up the $250 and buy a new master cylinder or is it worth purchasing a $90 rebuild kit? Experiences welcome.
Or purhaps someone has a new one sitting in there garage waiting for a new owner?  :bmwsmile
  • PA
  • 1995 K1100LT
Re: K1100 LT Rear Brake Master Cylinder - Recommendations
« Reply #1 on: October 19, 2016, 05:58:43 AM »
Examine the bore for scoring and pitting, if these are absent or can be eliminated with a light hone a kit would be fine.
Offline BK575
« Reply #2 on: October 21, 2016, 05:18:04 PM »
Thanks for the feedback Martin!
I did hone out the cylinder and didn't notice any pitting, just a good amount of dried brake fluid. I might go for the rebuild kit.
  • PA
  • 1995 K1100LT
« Reply #3 on: October 21, 2016, 06:01:38 PM »
 :2thumbup: Make sure it is scrupulously clean, and assemble using brake fluid as a lubricant. You can also put silicone grease under the boot, it will help prevent water and road crud getting in. Periodically clean out under the boot and regrease.
