Author Topic: Need to Rivet... Side Cases  (Read 6747 times)
Offline jay1622
« on: September 20, 2016, 01:03:35 PM »
I'm sure it's easy as pie, but it's something I've never done so I figured I'd ask you all... I need to drill out and swap the lock stops on my side cases. The one on the left is new, but is incompatible with my inner side cases. Something called a "pop rivet" should work, yes? I'm guessing that's what these are?
  • Charlotte
Re: Need to Rivet... Side Cases
« Reply #1 on: September 20, 2016, 01:22:27 PM »
Yes. I'v used both aluminum and stainless pop rivets when replacing loosened or damaged rivets. Use the smallest effective bit to remove them.
Offline jay1622
« Reply #2 on: September 20, 2016, 02:03:44 PM »
Will do... And, thanks for the warning. Makes sense.
  • Charlotte
« Reply #3 on: September 20, 2016, 07:32:48 PM »
I recently did mine including buying a coupe of new latches from Max BMW that came with rivets.
The ones that came with the new latches worked great but when using others you have purchased yourself make sure you get the right length, if memory serves you need 3/4" not 1/2" long for them to work
« Reply #4 on: September 20, 2016, 09:46:07 PM »
HomeDepot carries replacement latches.  This one has lasted longer than the BMW pot metal original.
Offline RobP
« Reply #5 on: September 21, 2016, 08:13:58 AM »
Use a rivet washer on the underside to keep the small expanded section of the rivet from pulling through the poly case.
  • Driftwood, TX
  • 1985 K100RS
Offline jay1622
« Reply #6 on: September 22, 2016, 03:29:25 PM »
All of this is great advice. Thank you.
Chaos, it's gotta be OE. Everything's been OE. Except for the grips.  :2thumbup:
  • Charlotte
Offline herseyb
« Reply #7 on: September 22, 2016, 04:26:40 PM »
I, on the other hand, will be headed to home depot for a new latch.  Thanks Chaos.
  • Brooklyn
  • '93 K1100RS
Offline jay1622
« Reply #8 on: September 26, 2016, 10:18:44 AM »
I went with 3mm x 10mm. Very sound words of advice; it truly saved me some cursing and an extra trip to the hardware store.
  • Charlotte
Offline jay1622
« Reply #9 on: September 26, 2016, 10:22:36 AM »
When I went to disassemble the rivets on my cases, the washer side went against the plastic part and the plunger portion of the rivet was against the metal cleats. Those were the newer versions. Mine cleats are plastic. I went with using the plunger and 1/8 inch rivet washers on the outer part. Worked like a charm!
  • Charlotte
« Reply #10 on: September 26, 2016, 12:55:16 PM »
 :2thumbup:  Understood, You'll miss out on the superior case hinges though!
