Author Topic: K100 handlebar replacement  (Read 12563 times)
Offline TNastsyDwnTwn
« on: September 09, 2016, 06:42:47 PM »
I am changing my k bike into a scrambler and I have ran into a problem with the handlebar. For some reason the throttle trust won't slide onto it. I bought a 7/8 bar. Any suggestions will be appreciated.
  • Laurinburg NC USA
  • 1985 k100rs
Re: K100 handlebar replacement
« Reply #1 on: September 09, 2016, 09:31:15 PM »
Despite what advertisements may seem to imply, ⅞" is greater than 22 millimeters—the dimension of BMW K-bike handlebars. Many people just sand down the ⅞ handlebar until the BMW controls will slide onto it. Your challenge is not uncommon. What you mean by throttle trust I'll figure out after I get some sleep.
« Reply #2 on: September 09, 2016, 09:36:33 PM »
I meant throttle twist. Sorry. I guess that's what I will have to do tomorrow. Thank you.
  • Laurinburg NC USA
  • 1985 k100rs
« Reply #3 on: September 09, 2016, 09:39:29 PM »
Thanks. I'll stay awake a little longer then.
« Reply #4 on: September 09, 2016, 09:41:10 PM »
ok thank you. What is the procedure to lubricate the the twist handle so it will return to its previous position.
  • Laurinburg NC USA
  • 1985 k100rs
« Reply #5 on: September 09, 2016, 10:11:44 PM »
You'll find instructions on the procedure in a pdf in this post right here. I'll add that you must be certain that the flange on the throttle grip isn't making contact with the throttle/master cylinder assembly because friction from that will slow the return, too.
You'll find instructions on this and other procedures in the Technical Library Card Catalog (Index).
« Reply #6 on: September 09, 2016, 10:16:05 PM »
Thank you so much. I appreciate it. :2thumbup:
  • Laurinburg NC USA
  • 1985 k100rs
« Reply #7 on: September 09, 2016, 11:09:24 PM »
Resist the temptation to hammer it  :nono   on, sand it down until it slides on.
« Reply #8 on: September 09, 2016, 11:12:54 PM »
I came very close but I resisted the urge! So what exactly would be best to sand the bars down with?
  • Laurinburg NC USA
  • 1985 k100rs
« Reply #9 on: September 09, 2016, 11:45:18 PM »
You're going need an experienced handlebar sander for that answer. I'm just an observer.
« Reply #10 on: September 10, 2016, 12:39:20 AM »
Emery strip on a roll, keep rotating it so you get it even, you could also use a file. Wrap a few of layers of tape to mark the length you require, this should stop you from marring the rest.
« Reply #11 on: September 10, 2016, 12:40:23 AM »
Ok just making sure by hand would be the suggested way.
  • Laurinburg NC USA
  • 1985 k100rs
Offline Shiny
« Reply #12 on: September 12, 2016, 06:37:56 AM »
So TNasty, you asked in my thread what I ended up doing:
I attacked the problem from both directions, I sanded the paint off the grip portions of my new 7/8" bars and I filed the internal diameter of the bmw controls. It doesn't take much, but it is extremely tedious. Took probably an hour and two beers. Use a rat tail file, about 3/8" round.
  • Northern Virginia
  • BMW K75T
« Reply #13 on: September 12, 2016, 11:59:37 AM »
Ok thank you. I used a dremel tool on mine. Thank you.
  • Laurinburg NC USA
  • 1985 k100rs
