Author Topic: The fourth fourth final drive bolt  (Read 4051 times)
Offline Motorhobo
  • +25 years of K75
« on: June 22, 2016, 05:55:36 AM »
Has anyone figured out how to get a torque wrench on the upper right FD / swing arm bolt? I can't get a hex socket on it even with a 3 in wobble extension. Been hand tightening with the stock Allen key for 15 years -- if anyone has an alternative I'd be grateful.
Thanks --
Re: The fourth fourth final drive bolt
« Reply #1 on: June 22, 2016, 07:27:27 AM »
If what you've been doing has worked for 15 years, keep doing it. Some people have a good internal sense of torque values and you're one of them. I don't recall having a problem when using a ¼ inch-drive metric torque wrench and hex socket with the wheel off.
Offline Motorhobo
  • +25 years of K75
« Reply #2 on: June 22, 2016, 11:07:59 AM »
It's not that the hex key doesn't work, it's that it's too much work. 1/4 turn at a time is all there's clearance for and it's annoying.
I'll see if I can find a hex socket that size for my 1/4 drive torque wrench -- I have a set of 1/4 drive hex sockets, but it didn't include one that big. BTW that's a lot of torque for a 1/4 in torque wrench.
« Reply #3 on: June 22, 2016, 11:14:19 AM »
I use a ¼ to ⅜ drive adaptor on my torque wrench. The torque value for those bolts is within the settings on my wrench and when I'm tightening them I usually have nothing else to do anyway, so they can take their time.
Offline Motorhobo
  • +25 years of K75
« Reply #4 on: June 22, 2016, 02:22:33 PM »
OK, thanks, didn't think of using an adapter, I'll give it a try.
