Author Topic: New Zealand 1984 K100 Naked and wanting  (Read 58801 times)
Offline Angus Macgyver
« on: June 19, 2016, 10:52:31 PM »
The Velcro gloves are removed, the sheep are safe as they say down here in New Zealand.
Winter project time.
1984 K100 factory naked
Bike arrived on truck from down the line, previous owner said he hadn't used it for some time.
A quick ride round the block a few times, ran fine, then into the garage to be reborn.
History from what I gathered during pull down.
Previous owners were all cheap skates.
Some of the most horrendous DIY repairs I've ever seen. Plastic drain pipe glued into rubber boot splits, wires twisted together unsoldered, flogged out fork seals, sealant piled up to replace missing grommets, Harley Davidson handle bars ground down to fit the 22mm hand switches.
Plastics cracked on " pooh'ed up " repairs - ( pooh we call bog, or automotive panel repair  filler)
Boat screws !!!!!! - I hate boat screws !!!!!!
I will say, the bike grew on me for its simplicity ( barring the cornacopia of electrical du dakkiz )
Very easy to pull down, ( unlike a Widow Maker Suzuki TL1000 ) room to actually swing a spanner ( unlike Japanese rice rockets ) and built sturdy, ( unlike Chinese dirt bikes .... )
Not a single nut rounded, not a single snapped bolt, even though they looked like they had never been touched before.....
No owners manual, just this forum and I had the bike completely stripped down to the engine in a day.
Thankfully my IPads wireless connection stayed strong all the way down to the backyards garage.
Every query I had, already discussed here with replies and solutions - fantastic !!!!
Wire loom cleaned up ( broke wire on fuel level sender only issue I came across )
I will be using factory instruments but seated lower and behind a street fighter front fairing
Replaced key ignition power wire ( looked bit melted from previous issue when frame rubbed through on steering head )
Engine booked in for soda blasting
Wheels were ok ( previous owner must have powder coated recently )
Transmission pulled , clutch and drive splines lubed ( no leaks yay)
Front forks rebuilt ( again easily done, no dramas, previous owner has installed spring kit )
Rear suspension looks sad, will hunt for replacement
Bike came with a Motad muffler but I'll use a 4:1 and a Yoshimura muffler
Rest is all usual surgery items
New steering head bearings
New wheel bearings
New fork seals
Clip ons
LED instrument upgrade
LED turn signals
50A alternator upgrade
Starter motor rebuilt
Twin headlight
Front fairing
Adjustable fuel pressure
MAFS big pod filter modification
Paul Smart Ducati tail unit
Braided brake lines
New radiator hoses
New fuel line
New breather hose
All new stainless hose clips
New manifolds
New swingarm boot
New clutch arm boot
Fuel rail cover ( hides that fugly fuel rail, wires and clutter )
Gen3 fuel injectors ( 4 spray holes )
Cut foot peg mounts ( no rear sets, NZ laws now too strict )
Shorten front wheel guard
Cut and shorten original rear wheel guard
Replace missing rubber grommets
Cut frame and tank side cover lugs
I will use the radiator and tank cover plastics ( cause these are rare as hens teeth ) hides that empty space when folks don't have these " rare as hens teeth " - cough cough...scored a second set..cough cough.
Some pics of the usual suspects.
  • New Zealand
  • 1991 Ducati 750SS 1984 K100 cafe racer, 1991 K100 RS, 1986 Suzuki GV1400 Cavalcade, 1981 Suzuki 820 Katana
" The people are fickle and easily manipulated "
1702 officer of the Royal Navy of England.
1984 BMW K100 cafe racer
1991 BMW K100 RS
Offline The Dude
Re: New Zealand 1984 K100 Naked and wanting
« Reply #1 on: June 19, 2016, 11:39:56 PM »
No fecking rearsets!What about forward sets?
New Zealand laws now too strict.....Which one of them told you that?
I'll have to have a quite word with "them".
Let me know please.Use code' they're probably monitoring... now. :finger:
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #2 on: June 19, 2016, 11:53:02 PM »
Yip.
The low volume motorcycle certifier here in Auckland , Alex Gee is his name. He's a good guy, works very closely with bike shops and LTNZ.
So many rules now.
Even X raying welds on clip ons .....
No longer just low volume once off, it's for wof now so dot on indicator lenses headlights.
Any alterations to seat, handling, brakes requires low volume cert ....!!!!
Up to the builder if you follow the law.
I run bike business...so I have to for resale.
  • New Zealand
1991 BMW K100 RS
Offline The Dude
« Reply #3 on: June 20, 2016, 12:04:04 AM »
Bummer!....
Yip.
Oh well, that's allright then.....er, thanks.
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #4 on: June 20, 2016, 07:51:56 PM »
Soda blasting.
Sent 32 years of muck away in the wind 😄
Once home, a quick wash down with water to neutralise the Ph level, cloth dry then fine spray of oil, then rub down with a happy ending....😂🎉🎉
More parts arrived at work from the UK, so assembly will can soon start on the engine.
I was going to use engine aluminium paint, but I like the raw finish the soda blasting produced.
Some corrosion and staining from past oil leaks will be hand polished out.
  • New Zealand
1991 BMW K100 RS
« Reply #5 on: June 22, 2016, 01:15:28 AM »
Boxes arrived at work, so skived off early and heading home to the cave.
Really not liking those factory manifold clamps, I will try to locate screw in adjusters.
Air box turned around and I will have the MAF sensor on left side or bike with large air pod ( purely cosmetic, can't see any performance gain though it does really open up the right side for viewing the engine.
Re tap crank breather connection or run a catch tank.
I made an alloy catch tank for my 150cc bucket racer, yes added weight and not really useful unless racing, but im fond of bling.
  • New Zealand
1991 BMW K100 RS
« Reply #6 on: June 22, 2016, 01:24:25 AM »
Rebuild the starter motor today.
Bit of a pain, the rebuild kit from eBay , the top post and brush was different than original, so I had to fluff around a bit swapping that bush over.
Bit of 1000 wet and dry clean up the contact points, bearing, seals, O rings.
Great thing about 32 years of caked on oil.... It protects the metal underneath.
Quick scrub N rub almost like new.
  • New Zealand
1991 BMW K100 RS
Offline The Dude
« Reply #7 on: June 22, 2016, 04:36:12 PM »
[quote author=Angus Macgyver link=topic=8503.msg65420#msg65420 date=1466572528
[/quote]
What fun putting the air box on wrong.I love idiocy,when it's well thought through.
I,also,love bling as long as I don't have it.Your beautiful aluminium oil catch tank beats my effort,which I found lying in the ditch one day when I overfilled the sump oil on the Guzzi and found out the hard way.Works well...
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #8 on: June 22, 2016, 06:40:11 PM »
MAF sensor box gone, I like the pod filter look.
Mounting right side = hot engine air.
Mounting left side = cold air
There is no wrong if it fits 😄👍
There is only custom coolness points
Lol😄 Don't get me started on Motoguzzi's.....
Guzzi the Italian Harley Davidson.
Glad to see they finally designed a 4 valve/cylinder engine
That starter motor though.... 😄 Need an engine lifter to get it out.
I had the 1100 Sport
One clutch change on a Guzzi was enough to put me off for life.
  • New Zealand
1991 BMW K100 RS
« Reply #9 on: June 22, 2016, 10:33:57 PM »
It was just meant to be 😄
Will get custom air box connection made from 70mm to 60mm right angle.
Plug connection is in a good water proof position
Question is, will a fully clamped air box handle a bouncing MAF sensor off the side, even with an internal mount plate?
One can only but try.
Update:
Air box requires very little modification.
Easily done with a heat gun and 22mm bar ( old handle bar )
The aim is to heat the airbox edge that the throttle cable guide sits under and press the plastic inwards.
You are looking to see the plastic go glossy, this is the correct heat without damaging the plastic.
Apply heavy pressure to your 22mm piece of bar and roll/Rock like a rolling pin.
This effect pushes the plastic inwards.
Remove the two closest manifold rubbers
30 seconds heat with a thin nozzle tip to direct airflow onto the work area
10 seconds of firm downward pressure, rolling then hold down on your bar till plastic cools a little ( this will stop the plastic memory bouncing back to its old shape)
I had to use two hands and get my whole body on top of it ........... So don't be shy with the pressure
Rinse and repeat
Other ways to gain a few mm clearance:
Grind off the outer edge of the cable guide top and corners will gain 2mm
Change the angle of the cable guide by banging flat and re bending slightly.
Airbox was reshaped within 40 minutes
Don't rush it, take your time, the plastic is quite thick and does require a good bit of firm rolling/pressing
Light sand to flatten rough edges and repaint with truck seal/ bumper paint
( manifold edge was already creased from previous owners rough figment of manifolds ) The heat will not damage the manifolds because your nozzle tip keeps the heat within a very small area .
  • New Zealand
1991 BMW K100 RS
Offline The Dude
« Reply #10 on: June 22, 2016, 11:58:52 PM »
Yeh,I know,but I just lurve ma Guzz....mine's a pert little 850 'had it for thirty loyal years,the clutch is bullet proof (on them),so's the cranking motor,yes that's what I call it and the little tart is a hard arsed blast but,man,is it hard on my arse?
Now, back to reality.Your maf sensor will be fine hanging out there.It's design has an integral air damper. Nothing like syrupy cool,air for better mass flow through the engine upping the thermodynamic efficiency.  :deal: 'Noticed how well they run when your wet n cold?
I'm keeping my brick standard as I view her as the good ol' missus,she's there to keep me in line,mostly.
All the best.
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #11 on: June 23, 2016, 12:42:37 AM »
All the best.
My other bricks stock.
Rode my Guzzi back from Christchurch to Auckland 2 days hard ride and I mean hard.
It's almost like Guzzi used a 4x2 and covered it with Rhino skin for softness. I was literally crow bared off the bike by my dad I was so stiff, everything aching, I think my wrists go left back in Wellington.
Awesome sound though, and when you crack the throttle at the lights, the whole bike lurches sideways 😄
  • New Zealand
1991 BMW K100 RS
« Reply #12 on: June 23, 2016, 12:49:25 AM »
Rebuild/repair gear position sensor.
# Silicon/sealer of your choosing
# Cheap Chinese starter solinoid cover ( those ones that pit bikes use )
Scrape old cracked top and old sealer out.
Re coat with new sealer
When dry, trim off the covers overhang with a razor blade, fit made in Vachina rubber cover, fits like a glove.
  • New Zealand
1991 BMW K100 RS
« Reply #13 on: June 26, 2016, 10:59:28 PM »
Replaced original black coil units with red cap versions from a later model
Replaced awful factory throttle body screws for stainless cap screws
50A alternator quick wire brush, ordered new set of rubber drive cushions.
Scored a very BMW cafe racer radiator overflow bottle 😄
Tidied up my loom again, much happier
  • New Zealand
1991 BMW K100 RS
« Reply #14 on: June 29, 2016, 09:20:44 PM »
Airtech Paul Smart Ducati street race tail unit arrived today.
You pay for what you get.
Beautifully made carbon fibre reinforced piece.
There was a 4 week waiting list but I am very happy with the shape.
The overhang works well with the K frame, giving a false appearance of a straight frame from tank to seat.
The tail scallops compliment the tanks, as does the width
There is a huge rear compartment that can house all the electrics and a Lythium battery..
370mm at the widest edge
620mm long
Seat pad area 200mmx300mm triangle.
( Battery in photo is just to hold seat unit down on frame until I hoop the rear and build the electrics tray )
Now the hard process of clearing my work bench 😄 /lol who am I kidding ( arm sweeps it aside )
  • New Zealand
1991 BMW K100 RS
Offline jakgieger
  • itinerant farmer
« Reply #15 on: June 29, 2016, 11:20:28 PM »
Enjoying the thread! You are obviously living up to the name :bmwsmilehttps://en.wikipedia.org/wiki/MacGyver.
  • Kansas USA
  • 1989 K100rs se
« Reply #16 on: June 30, 2016, 12:56:54 AM »
Haha nice.
The true Mac would have fashioned his own tail piece out of tin foil and chewing gum.
The previous owner used up all the chewing gum on the hall sensor cover  :yow
( which has now been lovingly restored with the correct cork gasket and D rubber gaskets )
  • New Zealand
1991 BMW K100 RS
Offline The Dude
« Reply #17 on: June 30, 2016, 05:41:00 AM »
Looking gooood!
 :popcorm
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline SJM1975
« Reply #18 on: June 30, 2016, 02:04:52 PM »
That seat unit is a thing of beauty .. I wish I'd have seen it before I bought mine
  • Mansfield
  • Bmwk75
Offline jjs1234
« Reply #19 on: July 01, 2016, 11:07:13 PM »
Definitely pretty, I hope the foam seat is good and thick.  :2thumbup:
  • Northern California
  • 1984 K100
Mr. Creative
« Reply #20 on: July 06, 2016, 10:01:52 PM »
Exhaust collector update.
Well the wind and rain just won't stop, after 5 days away on business, I return to a small mountain of postal boxes and bike parts for the K100.
After returning the New Zealand made collector due to poor welding/grinding ( please see photos )
I used the refunded money to purchase another from overseas ( worked out about same price including shipping ) from the Cafe4racer website, to allow fitting of the 50mm Yoshimura sports muffler.
Compared side by side, I highly recommend the Cafe4racer one. A very good price, beautifully made.
Can't go wrong with a well made competitively priced part. Thanks Cafe4racer
First the NZ made one..... :mbird
Second the Cafe4racer made one  :2thumbup:
  • New Zealand
1991 BMW K100 RS
Offline The Dude
« Reply #21 on: July 07, 2016, 05:46:58 AM »
Sad to see crap stainless fabrication from a Kiwi crowd.
Professionally,I used to use Classic Sheet metals in Henderson, Auckland,who were very capable and particular....It wasn't from them,was it?
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #22 on: July 07, 2016, 07:52:16 AM »
No not that crowd.
I am not one to name names, but honestly, very poor workmanship.
Maybe the guy was just having a bad day?
The thing that gets me the most, was that he actually had the cheek to send it.
Like a factory second fished out of the rubbish bin.
If the milks smells sour, I ain't the kind of pussy to drink it  :neener:
  • New Zealand
1991 BMW K100 RS
« Reply #23 on: July 07, 2016, 08:05:51 PM »
New rubber dampers for 50A alternator.
  • New Zealand
1991 BMW K100 RS
« Reply #24 on: July 09, 2016, 07:46:47 PM »
Installed Genssi type S adjustable fuel pressure regulator.
This regulator is well priced at around $30-$40, well made and has high ranked reviews.
With the large diaphragm , the unit is more than capable of keeping up with anything the K will ever hope to offer.
Very easy adjustment function but more importantly, with the engine open for viewing, bystanders get to gaze in wonderment at your oil filled glass gauge.  :clap:
* Regulator can be mounted at any angle, the standard bracket is slightly too low for good hose clearance, though turning on an angle allows good clearance.
You could make up a new bracket if the vertical placement looks more appealing....
* Fuel resistant pipe thread sealant paste is a must use, also Loctite on the small mount screws that came with the kit.
  • New Zealand
1991 BMW K100 RS
