Engine swap K75S 740cc trade for a 987cc from a k100
Topic: Engine swap K75S 740cc trade for a 987cc from a k100 (Read 9543 times)
Devil K
Motobrick Curious
June 10, 2016, 05:08:54 PM »
Do you guys think it's possible to transplant a k100 motor into a k75 and if so is there a difference in their transmissions, drive shaft, and final drives?
Kernville
1994 BMW K75S
Martin
Re: Engine swap K75S 740cc trade for a 987cc from a k100
Reply #1 on:
June 10, 2016, 05:20:51 PM »
Front down tubes are different, probably cheaper to buy a K100 and sell the K75. Transmission drive shaft and final drive ( different ratio ) will fit.
North Lakes Queensland Australia
1992 K75s Hybrid, Lefaux, Vespa V twin.
K1300S
Reply #2 on:
June 10, 2016, 07:24:27 PM »
Nor will the 4cyl fit under the S bodywork....
Martin
Reply #3 on:
June 10, 2016, 10:04:38 PM »
Marshall about 12 years ago there was a guy in the BMWMCQ who did fit K75s fairing to a K100 minus the belly pan. I have looked for pictures on their website but have been unable to find them.
K1300S
Reply #4 on:
June 10, 2016, 10:25:18 PM »
That is only part of the package. No complete S fairing. ...it doesn't count!
Martin
Reply #5 on:
June 10, 2016, 10:34:45 PM »
Does so, some K75s did not come with a belly pan, it was originally optional, so there. Nana nana nah nah. :neener:
Regards Martin
Martin
Reply #6 on:
June 10, 2016, 11:44:23 PM »
Marshall just for you I finally found a picture of the K100s and it had a belly pan.
jakgieger
itinerant farmer
^ SuperNatural Motobricker
Reply #7 on:
June 11, 2016, 08:00:22 AM »
K100 belly pan...
like on my avatar
Kansas USA
1989 K100rs se
"What we've got here is failure, to communicate. Some men, you just cain't reach. So you get what we had here last week. Which is the way he wants it...Well, he gets it. I don't like it any more than you men do."
Devil K
Motobrick Curious
Reply #8 on:
June 11, 2016, 02:43:34 PM »
So my question is, is there anyone out there who could give me advice on the motor swap. And you are saying that it is possible?
Kernville
1994 BMW K75S
johnny
TrailBrakingThrottleWhacker
Reply #9 on:
June 11, 2016, 02:46:45 PM »
greetings devil k...
it is possible with the right shop equipment... plasma cutter... tig welder... tube bender... frame table and so forth...
Martin
Reply #10 on:
June 11, 2016, 04:51:02 PM »
+1 Johnny but anything is possible, but it will require
modifying
the frame, a procedure that should be done by
experienced
persons.
Martin.
bmwrn
Curious
Reply #11 on:
February 13, 2017, 07:52:21 PM »
I think that the K75RT frame is a K100 frame. The radiator shroud from a K100 bolts on to a stripped RT. I understood that the K75 RT was built on the K100 frame to save reengineering the K75RT.
I d
[size=78%]on't have a reference for this, only my experience with my stripped RT :2thumbup: [/size]
Chaos
Administrator
Mars needs women!
Reply #12 on:
February 13, 2017, 08:15:15 PM »
I bet a 3 cylinder turbo diesel from a smart car would fit.
sw ohio
1987 K75S VIN 0231
Martin
Reply #13 on:
February 13, 2017, 10:29:40 PM »
bmwrn definitely different front down tubes between a K75 and a K100.
Dennis de Vries
^ Motobrick Curious
Reply #14 on:
February 14, 2017, 01:27:46 AM »
As mentioned a few times now, the downtubes are different as the k75 lump is one pot short but you are welcome to prove us wrong. You are right on the k75rt running a k100 rad but that has been done to prevent it from overheating when touring fully loaded 2 up in a hot environment... Bit overkill if you ask me...
Verstuurd vanaf mijn HUAWEI CUN-L21 met Tapatalk
Holland, Europe
'89 K75RT
