Author Topic: Engine swap K75S 740cc trade for a 987cc from a k100  (Read 9898 times)
Offline Devil K
« on: June 10, 2016, 05:08:54 PM »
Do you guys think it's possible to transplant a k100 motor into a k75 and if so is there a difference in their transmissions, drive shaft, and final drives?
  • Kernville
  • 1994 BMW K75S
Re: Engine swap K75S 740cc trade for a 987cc from a k100
« Reply #1 on: June 10, 2016, 05:20:51 PM »
Front down tubes are different, probably cheaper to buy a K100 and sell the K75. Transmission drive shaft and final drive ( different ratio ) will fit.
« Reply #2 on: June 10, 2016, 07:24:27 PM »
Nor will the 4cyl fit under the S bodywork....
« Reply #3 on: June 10, 2016, 10:04:38 PM »
 Marshall about 12 years ago there was a guy in the BMWMCQ who did fit K75s fairing to a K100 minus the belly pan. I have looked for pictures on their website but have been unable to find them.
« Reply #4 on: June 10, 2016, 10:25:18 PM »
That is only part of the package.   No complete S fairing. ...it doesn't count!
« Reply #5 on: June 10, 2016, 10:34:45 PM »
Does so, some K75s did not come with a belly pan, it was originally optional, so there. Nana nana nah nah. :neener:
Regards Martin
« Reply #6 on: June 10, 2016, 11:44:23 PM »
Marshall just for you I finally found a picture of the K100s and it had a belly pan.
Offline jakgieger
  • itinerant farmer
« Reply #7 on: June 11, 2016, 08:00:22 AM »
K100 belly pan... :bmwsmile like on my avatar
  • Kansas USA
  • 1989 K100rs se
Offline Devil K
« Reply #8 on: June 11, 2016, 02:43:34 PM »
So my question is, is there anyone out there who could give me advice on the motor swap. And you are saying that it is possible?
  • Kernville
  • 1994 BMW K75S
« Reply #9 on: June 11, 2016, 02:46:45 PM »
greetings devil k...
it is possible with the right shop equipment... plasma cutter... tig welder... tube bender... frame table and so forth...
« Reply #10 on: June 11, 2016, 04:51:02 PM »
+1 Johnny but anything  is possible, but it will require modifying the frame, a procedure that should be done by experienced persons.
Martin.
Offline bmwrn
« Reply #11 on: February 13, 2017, 07:52:21 PM »
  I think that the K75RT frame is a K100 frame. The radiator shroud from a K100 bolts on to a stripped RT. I understood that the K75 RT was built on the K100 frame to save reengineering the K75RT.
  I d[size=78%]on't have a reference for this, only my experience with my stripped RT :2thumbup: [/size]
« Reply #12 on: February 13, 2017, 08:15:15 PM »
I bet a 3 cylinder turbo diesel from a smart car would fit.
« Reply #13 on: February 13, 2017, 10:29:40 PM »
bmwrn definitely different front down tubes between a K75 and a K100.
Offline Dennis de Vries
« Reply #14 on: February 14, 2017, 01:27:46 AM »
As mentioned a few times now, the downtubes are different as the k75 lump is one pot short but you are welcome to prove us wrong. You are right on the k75rt running a k100 rad but that has been done to prevent it from overheating when touring fully loaded 2 up in a hot environment... Bit overkill if you ask me...
Verstuurd vanaf mijn HUAWEI CUN-L21 met Tapatalk
  • Holland, Europe
  • '89 K75RT
