Author Topic: Carbs on the brick  (Read 3106 times)
Offline Lewisrags2517
Carbs on the brick
« on: June 09, 2016, 04:24:32 AM »
Troops. New problem. I'm sacking the idea of injectors and thinking about putting gsxr 750 carb on it, my one and only question is----- what do you do with the injector holes, do I tap them and insert a nice looking bolt to cover the hole? I want this bike to be minimalist as possible. Help in this matter would be appreciated
  • Windsor, England
  • K100LT
Re: Carbs on the brick
« Reply #1 on: June 09, 2016, 10:12:11 AM »
I'm thinking plugging the injector holes would be the least of your problems.  JB weld and grinding them flat would probably work.  Long ago I saw a K75 with a single SU on a homemade manifold so it can be done.
« Reply #2 on: June 09, 2016, 02:56:24 PM »
after reading up on this... i have determined that kawasaki h2 mach 4 carbs will be the way to go...
« Reply #3 on: June 09, 2016, 03:02:20 PM »
Thank you for having a good dig around. I'll keep my eyes peeled :)
  • Windsor, England
  • K100LT
