Hi All..
I'm new the forum an to the brick. I bought a 1985 RS with only 9500 orig. km on it!!!! :euro But as I drove it back home I found it had very bad fuel economy (about 26 mpg (10,5 km/l)). I pulled the plugs and they were all back. I have read alot about this on the forum abput runing rich and the first i did was to take off the radiator, termostat and temp. sensor for the ECU box.
The termostat work fine, but the rubber was in bad condition - bought a new.
The temp. sensor work fine - bought a new to test against.
So new the head scratching began!! But then I came across the topic on the forum (
http://www.motobrick.com/index.php?topic=3509.0) were Inge K. suggests to check the wiring from temp. sensor til ECU (L-jetronic). I did this and found the resistance was much higher when I messured at the big connecter!!! So even when I drop the temp. sensor into 100 degree celsius water the resistance do's not come under 5 kOhm.. Which will make the L-jetronic think the bike is about 4 degrees all the time - ergo rich fuel mix!!
Now comes My real question - How do I fixit??? Can I buy the a new wire loom?? Is it better to repair?? The wire loom from the L-jetronic has alot of other wires goning in and out, so i not sure I would do it my self, even though I have work on many bikes before (mostly 70's honda, bmw, moto guzzi - wiring not to complex)
Hope some one has a good idea..
Best regards
Thor Meyer
Denmark
