Author Topic: K100RS running rich  (Read 16819 times)
Offline thormeyer
Re: K100RS running rich
« Reply #25 on: June 18, 2016, 11:27:01 AM »
I have a hard time believing that the regulator i at fault. I have replaced the old one, and there i no change from the old to the new, so I think old one was working fine. Maybe the vacuum is not working, but I put new hoses on and there is suction from the engine.
I had the lid open, and there were some ripples/movement of the fuel, but I could be from the running of the engine.
Is there a valve in the return line that maybe is not working?
I think the best thing to do is pull of the tank and check all the pipes inside - right?
Any other good ideas?
/Thor
  • Copenhagen, Denmark
  • BMW K100RS 1985
« Reply #26 on: June 18, 2016, 11:36:04 AM »
You are running two threads for the same topic, Thor, and apparently missing responses in one of them. That's not helpful. Read these posts then go to the other thread and redirect people to this one.
http://www.motobrick.com/index.php/topic,8489.msg65148.html#msg65148
http://www.motobrick.com/index.php/topic,8489.msg65130.html#msg65130
  • 1995 K75 89,000 miles
Offline thormeyer
« Reply #27 on: June 18, 2016, 09:52:30 PM »
sorry Laitch... and yes. my bad...!!!
i'am new too the forum and i have made two topic's with the same problem.. please use the other forum if you have comments..
/thor
  • BMW K100RS 1985
Offline thormeyer
« Reply #28 on: June 20, 2016, 02:05:47 PM »
update from Copenhagen..
I found the problem!!! and the bike now purrs like a kitten!! The culprit was a stuck fuel return valve (the small steel ball was rusted).
So pulled it out and cleaned the it but the ball was to rusted, so now I'm driving without.  :riding:
The pressure is now spot on and only need to put the plastic back on and go for a ride..
Thanks for all the help..!!!
Best regards
/Thor
  • BMW K100RS 1985
Offline Elipten
« Reply #29 on: June 20, 2016, 11:38:41 PM »
Where is that located?
  • San Antonio, TX
  • 1990 K75RT
Offline thormeyer
« Reply #30 on: June 21, 2016, 02:48:45 AM »
under the tank - the returnline is connected to it. I believe it was removed from 1985 model and up by BMW..
/Thor
  • BMW K100RS 1985
Offline Elipten
« Reply #31 on: June 21, 2016, 07:11:34 AM »
Thanks and no wonder I have not seen it on my K75
  • San Antonio, TX
  • 1990 K75RT
