Author Topic: 1991 BMW K 1  (Read 4812 times)
Offline Donmystic1
1991 BMW K 1
« on: June 03, 2016, 10:09:38 AM »
On my 1991 K 1 left side knee pad there are three switches.
Hazard and ABS. The third is a blank
What is the function of the ABS switch?
I would think that ABS brakes would be on all the time.
Don
  • Mystic, CT
  • 1985 K100, 1985 K100RS, 1986 K100RS Turbo,1985 K100RT
Re: 1991 BMW K 1
« Reply #1 on: June 03, 2016, 10:22:03 AM »
I did a quick search, using the search button, and found out it's for resetting the ABS system.
Offline Donmystic1
Re: 1991 BMW K 1
« Reply #2 on: June 03, 2016, 10:28:00 AM »
So it would normally be in the off position ?
  • Mystic, CT
Re: 1991 BMW K 1
« Reply #3 on: June 03, 2016, 03:20:37 PM »
there should not be an "on" position.  should be spring loaded and only function is to temporarily kill the abs warning light if there is a malfunction.
Offline Donmystic1
Re: 1991 BMW K 1
« Reply #4 on: June 03, 2016, 03:33:35 PM »
Mine seems to be a rocker switch.
Down the light on the switch comes on. Up it goes off
It does not appear to be spring loaded.
  • Mystic, CT
Re: 1991 BMW K 1
« Reply #5 on: June 03, 2016, 03:54:34 PM »
Hmmm.  Maybe k1 actually allowed you to turn of the abs?
Re: 1991 BMW K 1
« Reply #6 on: June 03, 2016, 06:05:48 PM »
Or the spring has sprung.....
