Author Topic: aux. power plug in problems  (Read 5540 times)
Offline burntstick
« on: May 22, 2016, 11:38:45 PM »
wanted power for gps /cell phone. but the bmw type cig. iighter plug in blew the fuse on gps and burnt up 2 usb plug ins. riding a 91 k75 lt . ideas for electrically challenged ?
  • under tarp
  • 91 75rt or maybe 92
Re: aux. power plug in problems
« Reply #1 on: May 28, 2016, 02:50:32 PM »
Wired bassackwards?
« Reply #2 on: May 28, 2016, 03:09:42 PM »
The make and model of the GPS? The size of its fuse? Does the GPS work in a car? Does the socket charge the cell phone with no problem?
Offline pablooo
« Reply #3 on: May 28, 2016, 05:26:22 PM »
I had this one installed on my K100LT when I bought it but i've since then taken it off. Is this what you mean you're wanting to do?
  • Austin, Tx
  • BMW K100, FZ-07
Offline burntstick
« Reply #4 on: May 28, 2016, 06:37:32 PM »
my female power plug in is located directly off the alternator behind engine. was used previously to power a vest i think.needed a  male female convertor to be able to use cig lighter type plug in
  • under tarp
« Reply #5 on: May 28, 2016, 08:07:55 PM »
Where you've described is a non-standard location for the auxillary plug, so maybe the PO wired it backwards.  A vest wouldn't care about polarity, but your USB devices do care.  Make sure the centre pin is positive and the outer ring negative (ground).
Offline burntstick
« Reply #6 on: May 29, 2016, 12:07:42 AM »
thanks robert
  • under tarp
